Putting an extra turbo to the R33 GTST
supra
 Share
  • Replies 73
Originally posted by JimX
Two stock turbos will be able to be provide more boost to one engine because they're only feeding half the engine....
But they are feeding a common plenum chamber. The laws of physics dictate that the pressure will be distributed evenly throughout the induction system. Therefore you can only run boost equivalent to the lesser of the 2 turbos. So if you're running 9psi on each turbo, you can only run 9psi at the wastegates, and therefore 9psi at the valves. If you are running 18psi on each (ceramic) turbo, you are flirting with danger.
Hi stimps, "You can run 18psi with one of these turbos"
We ran 12 psi on an low K's R34 RB25DET turbo for 8 minutes and it did the usual ceramic turbine thing. I have 10 other examples on various RB20/25's, you are the exception not the rule.
"by having the right intercooler and tuning"
Firstly it is the combination of heat and resistance that causes the ceramic turbine to fail, not just resistance. Is is simple physics, turn the boost up and you have to retard the ignition timing otherwise it pings. When you retard the ignition timing, the spark fires later in the combustion stroke. Therefore combustion takes place later, such that at higher rpm the exhaust valve opens before the combustion is all finished and some actually takes place in the exhaust manifold and turbo. Bingo extra heat on the ceramic turbine. The more boost, the more retarded the ignition, the more combustion in the turbo, the more heat.
Add that to a few hard laps of the circuit or a long hard run on the freeway or drag strip and you will be picking turbine bits out of the cat.
Anyway, that's been my experience and 10 others I have fixed. Roll the dice if you like.
While I'm at it, "478kw at the wheels with a stock bottom end R33"
I could make a 1,000 bhp out of a standard RB25DET bottom end, on Elf Turbomax, shoot that's easy. But for how long, 22 seconds while I do 1 Shootout mode power run on the dyno?
Me, I like to drive my car at full power every day, whenever I like, rain, hail or shine, on the track, road or circuit. Fill it up at the local BP and I'm away.
Hope that explains my thoughts.
Hi stimps....
"is that with a stock cooler? "
no, HKS in a couple, GTR in a couple more, GReddy in 3, and a couple of locals - Micks Metalcraft and Performance Metalcraft. No Standards.
The JMS 478KW car.. Is that the one that boiled its brains out recently at Gawler?? I understand it blew the head gasket and split the cylinder head... and when they pulled the head of it had severe detonation on the piston crowns, and suspected broken ringlands. Or maybe that was another of their cars they pushed beyond the limit.......
The problem is heat in the exhaust, not heat in the inlet. The intercooler is irrellevant in this scenario. More boost at the engine = more retarded ignition = more heat in the exhaust.
Remember, it is not how hard you push it, but how long you push it.
Hey Sydneykid, don't want to start a "dynos runs and rwkW don't mean a thing, dynos are only good for tuning" argument, but just curious what the RB31det in your R32 makes? No other motives, just plain curious what a long stroke monster will make
The JMS R33 was running around the 350rwkw mark at the Drift Day.
I wondered if the motor had died as on its last couple of laps due to it bouncing off the rev limiter constantly I saw smoke emitting from the exhaust.
My Small RB20 turbo has been pretty good to me running 16psi since I got the FMIC around 1.5yrs ago.
Its not so much how much a long stroke motor will make its about where it makes it.
After looking at my RB30 block compared to a 250 Ford 6 motor the RB30 looks very small.
Hey Ronin09. There are 5 RB31's in the current batch. For curcuit racing, we have found anything more than 650BHP is actually slower, so we will be limiting the curuit engine to a very responsive 625BHP. One of them is going in a drag car, with twin 3037's, so it shgould comfortably make more than 1000BHP.
So it is really a matter of what you hang off the engine, as the internals have quite a large spread of horsepower potential.
Hope that answers the question.
Originally posted by stimps
oh, and japanese motorsport in sydney got 478kw at the wheels with a stock bottom end R33 so use that as a bit of benchmark when it comes to how strong the motor is. (in other words, bloody strong)
Just thought I would give JMS a call - they do not have a shop in sydney.
I would appear stimps you are either very confused or full of shit.
Either way I think it is a good idea to get stuff right before you start to post up making claims.
There is enough dis-information around already, adding to it doesnt help.
A warning to others that may listen too long or hard to your comments.
they must of shipped it to adelaide???? the car was built in adelaide, and resides in adeliade as does the owner, Danny Vahoumis, who is also the proprietor of JMS. The car travelled to sydney once, but that is a completely different story.
Also the car made 448rwkw, not 478rwkw.
You really should get things straight before you sprout them as truth - otherwise, as stated before, all you do is add to confusion and the already huge amount of disinformation on the net which helps no one.
Plus you have just shot your credibility to pieces on here.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
