as soon as i saw that it was a drive to harndorf
i now want to go there lol
its a nice place and those litre beers ohh yeah
hahndorf rocks. great schnitzels.... good drive
when i get my timing belt replaced i'd be keen :)
-D
I'm interested... oh wait.
Tis a good idea tbh. Takes under 30 mins to get there from a nice meet point like burnside council.... then a nice twisty drive around the backway out of there ;D
Gettin' the timing belt done this wed hopefully. Sat would be awesome for a nice sat morn meet and cruise up to the german arms or something
anywhere they serve beer, cabbage, sausage and gravy. german style. sehr gut
-D
-D
Common Ben this saturday is the dyno day
come and check it out and support your sau peeps
if i remember correctly
last year that had the sausage sizzle and shit
so i would assume that they would be doing it this year as well
come and watch some beasts on the rollers mate
i think your R should be on there...common ben dont be shy
lol i apologise for having other commitments, not like my 200kw would do much, a standard 2j would eat me. I have cricket, ill def be attending more of these events in the off season, which isn't far away.
nope just wanna see a bigger SAU presence this time around
its just a fun day lol....since your whimping out on us i gotta get other post whores out :)
Yeah don't mind Damo, he gets sad when his nick isnt in the 'last action' of the top 5 threads ;P
Dunno if I can be stuffed putting the car on the dyno.... costs money too right? Less money for dyno, more money for sausage!!!!1one
-D
i am only playing with ya playa
now i am begining to wonder whens the next SAU dyno day gonna be???
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
