Item: early model evo lancer
Website:
Item Condition: mint
Reason for Selling: change
Price and Payment Conditions $25,000ono
considering trade
Extra Info:
:all standard evo features inc.
:reinforced chassis
:recaro seats
:momo steering wheel and gear knob
:digital climate control
:rear wiper
:power everything
:lsd diffs front and rear (front lsd was a option)
:electric fold mirrors
:large front mount intercooler
:td05big 16g turbo NOW UPGRADED
:extremly strong gearbox REBUILT
:alloy vented bonnet
:larger brakes NOW UPGRADED
:intercooler water spray NOW UPGRADED
:large oil cooler
:factory tilt slide sunroof (very rare only 5% had them)
TOTAL MODS LIST TO DATE
MOTOR
: HKS adjustable cams gears
: Full Custom stainless 3 inch exhaust with polished double dump pipe and Jasma muffler
: Walbro 500hp fuel pump
: SARD fuel pressure regulator
: K&N panel air filter
: Turbosmart EBOOST 2 boostcontroller
: Mine's VX ROM ECU
: Turbo XS blow off valve
: NX custom EFI kit (wet kit) with 12lb carbon fibre bottle, purge kit with high performance solenoids and shark nozzle (worth over 3k)
: TDO5-20g turbo
: NX Ntercooler spray bar (sprays NOS on the intercooler)
: Upgraded earthing system
: Upgraded 110amp alternator
: NGK 10mm leads
LOOKS
: 17inch OZZY racing rims + 18inch VOLK TE37's for show
: BCI pollished billet plug cover
: Bosch 10,000k HID hi/lo head light conversion
: Blue silicone engine bay hoses
: Personalised plates DST16 ( The Stig) not inc in the sale
: Billet Ralliart oil filler cap
HANDLING & DRIVTRAIN
: G4 fully adjustable track spec coil over suspension
: Front and rear strut tower braces
: Federal 595 RS SEMI-SLICK tyres
: NPC high performance 3300lb custom clutch
: rebuilt gear box with new synchro's and synchro hubs
BRAKING
: Slotted disc rotors
: EBC Redstuff pads
: Stainless braided brake lines all round adr compliant
: PBR600F racing brake fluid
SAFTEY & GUAGES
: AUTOMETER Pro comp liquid filled boost gauge + carbon fibre cup
: AUTOMETER Pro comp air/fuel ratio gauge
: SPARCO 4 point racing harness
: MOMO harness pads
: Real carbon fibre floor panels
AUDIO
: Dual battery system for stereo
: Redarc smart solenoid
: 2X12in Sony Explode subs
: Kenwood D class amp
: MTX thunder front splits
: Sony Explode XM 4 channel amp
: Panasonic 6X9 rear speakers
: Pioneer 4 channel amp
featured in high performance imports mag issue 72
12.92sec best et 110.48mph best speed
205.5kw at the wheels
66 sec around QR sprint track
12 sec evo lancer with out the nos and with old turbo set up, will keep you informed after i have re run it
Pictures: see below
Contact Details: 0420 279 315
[email protected]
https://www.sau.com.au/forums/topic/260135-lancer-evolution-swap-for-r33-gtr/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
