NISSAN SKYLINE R33 GTS-T S1 M-SPEC
ENGINE:
RB26DETT conversion
RB26 sump w/transfer case sliced off
RB25 engine mounts
RB25 Harmonic balancer
HKS Intercooler
BLITZ front pipes
SIGNAL straight through carbon muffler
HKS Pod filters
Splitfire coil packs
TODA Racing clutch
TODA Racing 4.5kg Flywheel
CUSCO 2 way mech diff
IRIDIUM Plugs - 6's
R33 GTR fuel pump
SUSPENSION / BRAKING AND HANDLING:
SELBY rear 28mm sway bar
RACING GEAR coilovers
D1 rear camber arms
D1 HICAS lock
CUSCO front tension rod
Solid rear subframe bushes
D1 adj castor rods
PROJECT MU Slotted front rotors
TRW (LUCAS) brake pads all round
NISMO Front strut brace with brake stopper
GTR rear strut brace
BODYWORK & INTERIOR
Full body respray in Blood Orange
Satin Black bonnet and wing
SPARCO bonnet pins
NARDI Steering wheel
TRUST gear knob
SPARCO Spirnt drivers seat w/ BRIDE Rail
GReddy Profec B Spec II boost control
GReddy Turbo Timer
New Carpet
GReddy Boost Gauge
engine has spun a bearing , have R33 GTR Bearings to go on the engine
also have R33 GTR Crank that has been linished and polished with oil galleries filled with grub screws
R33 GTR Pistons & Rods
R33 GTR Oil Pump (Rebuilt)
Possibley interested in trades
Price $14,000 ono
would have more pics but GPU in my pc has died so i cant access the hard drives for now.
https://www.sau.com.au/forums/topic/260151-my-r33/
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
