1. Fixed racng seat with R33 seat rail
no damage and dirty, same as new
good for drift, $100
2. BOV for R33, can adjust, $20
3. HKS turbo timer without R33 hardness, $20
4. 2 steering wheels, one for street use and one for drift use, $40
5. Trust injection rail, stock injector size 10.5, 100%new with box, $100
6. Brake Rotor, $30, it has machined, 3 times machined left, $30
7. Roger Speaker, $120 very top sound
I live in Eight Miles Plains QLD4113
https://www.sau.com.au/forums/topic/260169-r33-parts-and-others/
Are the steering wheels $40 totals or each?
Can you please post up a better picture of the steering wheels so I can see the screw setup? Need to know if it'll fit my boss kit.
2. BOV for R33, can adjust, $20 (Hold)
3. HKS turbo timer without R33 hardness, $20 (Hold)
4. 2 steering wheels, one for street use and one for drift use, $40 (Hold)
6. Brake Rotor, $30, it has machined, 3 times machined left, $20
Edited by CTM508
cheers mate for putting them on hold for me i will see you on saturday to come and pick them up
7. Roger Speaker, $120 very top sound, Drop to $100
  • 3 weeks later...
Fixed racng seat with R33 seat rail, no damage and dirty, same as new, good for drift, $100
R33 2Dr 400R side skirt 100%new $100
PowerSplirit Power Stable Equipment $30
Unversal A-Pillar Pod 60mm $20
You can make an offer~ Thank
Edited by CTM508
Fixed racng seat with R33 seat rail, no damage and dirty, same as new, good for drift, $100 Drop to $80
Trust injection rail, stock injector size 10.5, 100%new with box, $100 Drop to $80
R33 2Dr 400R side skirt 100%new $100 Drop to $90
PowerSplirit Power Stable Equipment $30 Drop to $20
Apexi N1 damper for GTST33
it's can be adjustable only and rear ring may difficult to adjust
no oil leak and good condition $300 Drop to $280
OEM ignition coil packs with HKS plugs(used) $100 Drop to $80
Great condition for full packs and checked volt already
Trust Greddy BOV with R33/ER34 adaptor
$200~ same as new Drop to $180
you will get what in photo
They are the final price, any question PM me
Thank all
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
