  • Replies 589
Hey Tez
Should be good, ill be there with GTR-32X(bnr-034) , CYIFLY , AND Got another 5 mates who dont come on these forums with 34 gtr's , they should be all able to make it too ...
see you all there...
This looks like its gonna' be really succesful.
Lemme' clarify something before i screw up ..
Is this cruise R34s Only .
Or Show / Cruise is based upon the R34 Anniversary .. and we can have non-r34 spectators tag along ?
MRXTCZ
MRXTCZ
The R32 GTRs and R33 GTRs are due for their 21st and 15th Anniversary Celebrations next year.
The Participants for this year's Charity Cruise to Mt Wilson and prizes will be R34 GTRs in group #1 and R34 GTTs/GTs in group #2.
mxfly's whole idea is to Celebrate The Car's (R34 GTR) 10th Anniversary and go National with it...
(rather than have a local area cruise with all involved).
In other words, the parameters are changed to involve 3 Cruises. And consider this to be the 1st of 3!!! The emphasis is the Celebration!
This whole idea of mxfly's has grabbed the attention of Jason at High Performance Imports. Many thanks to Jason whilst he's offered a couple of his own suggestions.
There is absolutely no reason why other SAUers can't tag along Vicky. That's why it's great to live in Australia = a free country!
Many Thanks for offering to help as this may depend on whether or not a whole lot more are part of group #2.
Cheers,
Terry
bakes its about 2 hour drive, give or take.. Ill be heading down, so we could do a pre meet somewhere on the coast or something
Can we get a IN and OUT list.. recon it will be a massive list!
How far is the end point from P6 in hours?
Just trying to work out how big of a day it would be if I came, coming from Newcastle.
Hiya Bakes!
If I was coming from Newcastle, I'd be thinking of 2 options...
i) Newcastle > Homebush P6 leave 10am sharp > Richmond 45mins > Mt Wilson 55mins and then the photoshoot at Noon or
ii) Newcastle > Windsor > Richmond > Mt Wilson 55mins + photoshoot.
It'll be good to have you along. Black is beautiful.
Cheers, Tez
Thanks for the great response SAU members!
Terry, I will speak to Raf about leading/organising the convoy of 33s and 32s.
Cheers
Cool!
Thanks on behalf of Eugene and I~ Raf's a great guy
Yes we intend to compile a list of all participating as we need to know the general numbers for organising other things like food, etc.
But since I can edit the first post, I might decide to open another thread with all that are definites.
Bah sorry guys, I was hoping I'd be able to bring the N1 over, but it's a tragic date clash with All Japan Day here in SA (I'm one of the organisers, so I can really bail on it!). Bugger.
So sad 'K'. Would have enjoyed meeting you just as much as the N1!
...but just in case I can relocate an aftershock earthquake from Gippsland to SA, what are the exact GPS Co-ordinates of the All Japan Day site?
(Really - enjoy your big day out and we'll compare notes later) Tez
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
