More Good news!
Great Aron! So R34Liner is IN :cool:
mxfly will update the list in his OP as this thread gets longer!
In 20 days, there'll be a complete programme for all to see!
In essence so far, mxfly's idea has caught on! > This idea grabbed the attention of Jason at High Performance Imports who we are sticking by with loyalty - Thank You Jason > Another notable magazine became interested > a Japanese martial art organisation became interested > some prizes have trickled in through kind sponsors > and there's more...
  • Replies 589
Just a thought,
but wouldn't it be better keeping it as traditional japanese models. This is a celebration cruise. If you want pictures of your cars with models go to autosalon.
This is a one off. It should be different
I'm not saying don't have them
I just think it would be more appropriate to only have the traditional japanese models
in the end though its up to Terry and Eugene
Edited by Black Widow
Good news!
Bakes is IN :/ . Be good to see you again after Singleton! Is Ian coming with you?
Alan is IN :) . I was wondering last week Alan whether or not my local area commander would be good enough, or whether I need to contact the nearest Police Stn to Mt Wilson + Richmond?
Regards, Terry
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
    • I don’t mean this in any negative way. But, if u are after this type of data why don’t u have a flex fuel sensor?
