  • 1 month later...
  • Replies 589
  • 4 weeks later...
Some of our committee thought this might happen...
http://www.carsales.com.au/Tig/UI/PagePopu...mp;tabID=804367
Well why not? So long as the car hasn't gone off the boil since then.
I noticed he didn't use the Skaifey-signed version?
hmm..
Doesn't like skaife? LOL
Yeah i can't say i'm a fan of the stripes either...but he has them on the TRD hilux too so i assume he's a fan and that's all that matters i guess.
$125K seems a bit steep to me though??? Am i missing something? I know the car is built etc and has had a lot of money poured into it, but i just thought maybe that was a bit high given the cars actual condition (looked less than showroom in the pics..)
Yes, I'd feel short-changed if I couldn't have at least a copy of the original Award Certificate with Mark's signature!!!
I wonder if the new purchaser of Bakes' black-pearl received a copy of his Award Certificate signed M.Skaife?
It would look the goods on the office wall of his Coffs Harbour home. :D
  • 1 year later...
Fast Fours/Performance Imports DVD of this Event is out atm. :action-smiley-069:
Tucked in with PI Issue #134 as a complimentary item (at newsagents).
It's a reprise if you've missed it before.
  • 11 months later...
