Cef In North America
I've got an 89 A31 (and an 89 R32). Cefiros are rare in the US. I only know of one besides mine. I plan on drifting it.
Some info:
Factory 5-speed
Cheap ebay front mount ic
Custom exhaust
Bosch 040 fuel pump
KSRom ECU - Was already in the car, don't know the tuning
Custom one-piece drive shaft
Cusco coilovers on the front & Tein on the back. - Getting replaced with Powered-by-Max coilovers
Z32 brake & 5-lug conversion
Braided brake lines
Stock r32 wheels on the front & 17x8 +30 Work Equips on the back
Nice looking cars, bet you get some strange looks with the ceffy? even if it's a track only car lol
Most people think it's just a funny looking car but there are a few that are almost hostile about it.. I usually get harassed by the V8-Muscle-Car guys when I go to the track. But they are beginning to respect RB motors!
Are you allowed to drive it on the road if it's right hand drive?
Right hand drive isn't a problem. We have crazy emissions and safety laws that take a large mountain of paperwork and money to comply with. I still haven't been able to get the R32 registered.
Isn't the usual trick over there to acquire the VIN plate from a crashed 240SX and then "repair" your 240SX by welding in a Skyline shaped chassis around the remaining part of the 240?
Did you get the Ceffy registered at all? Presumably as a Maxima.
I don't even want to talk about all the hoops I had to jump through for registration. Lets just say I don't want to go through that again. Ever.
How ironic, when Detroit is churning out those massive SUV's :banana:
Feel sorry for you mate!
  • 5 months later...
My turbo died. Long live the turbo!
It's a Holset HE351. Very similar to the HX35.
Still have stock injectors so it leans way out and pulls timing.
With a bad tune and weak injectors it made 288hp (215rwkw) on 18 psi.
I'll post up a dyno chart when I get some injectors and a good tune.
Nice looking Ceffy mate.
What kit is that you've got on? Looks like a modified factory kit, but not quiet an Autech kit ?
Looks awesome...except for your Intercooler not sitting level, that looks a bit weird, make sure you cable tie that back up properly hey ? haha
The kit was on the car when I bought it. I don't know what it is, but it's not Autech. The intercooler is level now. I cut some off the crash guard to make it fit. :happy:
Must just be a modified factory kit? Did you get the car from Japan, or somewhere else ??
Front bars have to be cut in any case to fit a FMIC in, which sucks, over here cops love to give us trouble for it, apparently painting them black makes them invisible ? Havent tried it yet, but I know a black intercooler would make a white / light colored Ceffy look f**king mean.
 Share
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
    • Before and after of reflectors, two coats brushed on. i used a bucket full of hot water to to heat up glue, then pry the lenses out a little with a flathead screwdriver and cutting with a Stanley. I’m not sure how the paint will go but it’s my best chance without dipping.  see the reflection in the picture I’m pointing? That’s two coats paint and you can see the state of it in before shot after I cleaned it
    • roll and pump rear guards = you'll be fine mate
