I've got an 89 A31 (and an 89 R32). Cefiros are rare in the US. I only know of one besides mine. I plan on drifting it.
Some info:
Factory 5-speed
Cheap ebay front mount ic
Custom exhaust
Bosch 040 fuel pump
KSRom ECU - Was already in the car, don't know the tuning
Custom one-piece drive shaft
Cusco coilovers on the front & Tein on the back. - Getting replaced with Powered-by-Max coilovers
Z32 brake & 5-lug conversion
Braided brake lines
Stock r32 wheels on the front & 17x8 +30 Work Equips on the back
https://www.sau.com.au/forums/topic/260225-cef-in-north-america/
Nice looking cars, bet you get some strange looks with the ceffy? even if it's a track only car lol
Most people think it's just a funny looking car but there are a few that are almost hostile about it.. I usually get harassed by the V8-Muscle-Car guys when I go to the track. But they are beginning to respect RB motors!
Are you allowed to drive it on the road if it's right hand drive?
Right hand drive isn't a problem. We have crazy emissions and safety laws that take a large mountain of paperwork and money to comply with. I still haven't been able to get the R32 registered.
Isn't the usual trick over there to acquire the VIN plate from a crashed 240SX and then "repair" your 240SX by welding in a Skyline shaped chassis around the remaining part of the 240?
Did you get the Ceffy registered at all? Presumably as a Maxima.
I don't even want to talk about all the hoops I had to jump through for registration. Lets just say I don't want to go through that again. Ever.
How ironic, when Detroit is churning out those massive SUV's :banana:
Feel sorry for you mate!
  • 5 months later...
My turbo died. Long live the turbo!
It's a Holset HE351. Very similar to the HX35.
Still have stock injectors so it leans way out and pulls timing.
With a bad tune and weak injectors it made 288hp (215rwkw) on 18 psi.
I'll post up a dyno chart when I get some injectors and a good tune.
Looks good man!
Any more mods for the Ceffy before drifting?
Nice R32 GTR! A rear sight in the USA, so I guess your lucky!
Pics of the R32 engine?
Yeah... Um... Get some better offset wheels :D
Nice looking Ceffy mate.
What kit is that you've got on? Looks like a modified factory kit, but not quiet an Autech kit ?
Looks awesome...except for your Intercooler not sitting level, that looks a bit weird, make sure you cable tie that back up properly hey ? haha
The kit was on the car when I bought it. I don't know what it is, but it's not Autech. The intercooler is level now. I cut some off the crash guard to make it fit. :happy:
Must just be a modified factory kit? Did you get the car from Japan, or somewhere else ??
Front bars have to be cut in any case to fit a FMIC in, which sucks, over here cops love to give us trouble for it, apparently painting them black makes them invisible ? Havent tried it yet, but I know a black intercooler would make a white / light colored Ceffy look f**king mean.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
