Hi Guys,
I have an issue occurring on my fairly stock S2 R33 GTST Skyline. At full boost with the solenoid on the high setting (above 4500RPM) there is a squealing noise that comes from the intake side of the engine along with a black deposit on the inside of the bonnet, above the intake manifold. I am running the stock intake with SMIC and a K&N panel filter.
I have not had too much of a chance to look at it as yet - has anyone seen something like this before?
Cheers,
Christian
https://www.sau.com.au/forums/topic/260240-squealing-on-intake-side/
If you could measure or at least give a more accurate description of where the mark is, it would be a great help
Like I said, I have not had too much of a chance to look at this yet. The mark is above the intake manifold towards the front of the engine, and looks like carbon deposits so it may not be mainfold leak. It sounds like it comes from the intake side of the engine - behind the instrument cluster.
If its carbon then its not going to be your intake. Check for exhaust leaks. If there is carbon being deposited on the hood, then there should be some around the block or where the leak is at.
Sometimes sounds can be deceptive, it may sound like its comming from the intake side, but you are seeing carbon deposits which would make me think exhaust side. Mani or turbine.
Thanks heaps guys, I will check it out tonight once I get home from work.
Cheers,
Christian
    • I've got a spare standard box sitting in the garage  I know it will come one day though, but it's driven pretty tamely on the four times a year it gets out...
    • Big question… have you decided on a gearbox? Because it’s going to come… and a gearset ain’t going to do the job.    save your pennies 🤪
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
