hey guys.. i have a r33 GTS-T 94 modle. I am having problems with the breaks the front break pad keep squeeling and i had my disces machined and had 3 lots of new pad put in.. still they squeel.. now when the break place pulled the break pads out they are shines each time.. any ideas why this is happening..
https://www.sau.com.au/forums/topic/260298-break-pads/
BRAKES ffs!
Did you bed the pads in correctly? Are the anti-SQEAL shims behind the pads?
i got a new set of pad put into but i am sic of goin bak to the place get them changed.. but on the way home they started to squeel kinda again and not happy :D i was told to bed them u have to get to like to 80 then break fairly hard... and for th anti-SQEAL shims i couldn't tell ya sry..
https://www.sau.com.au/forums/topic/260298-break-pads/#findComment-4467053
heres some instructions for ya, and remember, DO NOT come to a complete stop... you can stuff your pads, probably the reason why you had to go back 3 times.
BEDDING IN INSTRUCTIONS
1. Install disc pads and check fit.
2. Pump brake pedal until pedal is hard.
3. Perform 2 stops from 50Kph to 20Kph with medium pedal effort.
4. Perform 6 stops from 110Kph to 70Kph with high pedal effort.
5. Drive vehicle for 10-15 minutes at 70 to 100Kph without using the brakes to allow them to cool
6. Park vehicle and allow brakes to cool to ambient temperature.
DO NOT STOP VEHICLE WHEN PADS ARE HOT DURING BEDDING.
THIS WILL SEPARATE THE PAD FORM THE BACKING PLATE
Bedding should not be performed until disc rotor has been bedded.
The disc pads will smoke and smell whilst bedding.
https://www.sau.com.au/forums/topic/260298-break-pads/#findComment-4470180
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
