lol mitch, you said your low and cash now you wanna upgrade to t51r :(
because this build is going to be done by monday isnt it damo (Y)
Hey mate,
Good luck with the engine... i have the same exctitng job to do this weekend... Pull out the engine.. then the following weekend put a different one back in... cant wait, sound like so much fun :S
same to you mate ,
hope you dont have any hicups in the process !
http://www.youtube.com/watch?v=Rv67yLI_jVs
RB30DET (26 head) T51r.
Pitty the bottom end is unable to rev (7000rpm limiter) due to the lack of a good aftermarket balancer. :D
Bugger all lag, no need to bounce it off the limiter to get it off the line quickly.
Edited by TheRogue
cant imagine running that with my current cusco 2 way mech diff though
what would be a better diff ?
1.5way ?
Locked ;):laugh:
would be fun :P
Not many other options if you already have a 2way mech diff. A 2 way is pretty much a locker as it locks under acceleration and deceleration, a 1.5 way only locks with acceleration
I have a Nismo 2way, can be a little tricky in the hills sometimes :P but its good for sliding :D
Edited by DSTROY
1 way only locks under accel. 1.5 ways partial lock under decel, and fully lock on accel.
but as chad said, 2 ways are practically lockers anyways. id probably be leaning towards a 1.5, but it depends entirely on how often itll see the street.
Damageinc,
Really depends on how quick acting the diff is. You can run a factory GTR diff that has shallow ramps and locks smooth and soft. A pleasure to drive.
Then jump in to one of the Nismo 2ways with a steep ramp and they lock with the slightest throttle or decel.
Then there's the preload.. For the street you really don't want more than 40-50lb where as the nismos for example are up around 70 so very tight.
Unless your running slicks or semi's you really don't need so much preload.
Damageinc,
ohk , ill just wait and see when my engine build is complete , see how it acts with the current lsd and then go from there .
i was thinking GTR Rear Diff from the beginning so...
cheers for the info :P
