lol mitch, you said your low and cash now you wanna upgrade to t51r :(
because this build is going to be done by monday isnt it damo (Y)
Hey mate,
Good luck with the engine... i have the same exctitng job to do this weekend... Pull out the engine.. then the following weekend put a different one back in... cant wait, sound like so much fun :S
same to you mate ,
hope you dont have any hicups in the process !
http://www.youtube.com/watch?v=Rv67yLI_jVs
RB30DET (26 head) T51r.
Pitty the bottom end is unable to rev (7000rpm limiter) due to the lack of a good aftermarket balancer. :D
Bugger all lag, no need to bounce it off the limiter to get it off the line quickly.
Edited by TheRogue
cant imagine running that with my current cusco 2 way mech diff though
what would be a better diff ?
1.5way ?
Locked ;):laugh:
would be fun :P
Not many other options if you already have a 2way mech diff. A 2 way is pretty much a locker as it locks under acceleration and deceleration, a 1.5 way only locks with acceleration
I have a Nismo 2way, can be a little tricky in the hills sometimes :P but its good for sliding :D
Edited by DSTROY
1 way only locks under accel. 1.5 ways partial lock under decel, and fully lock on accel.
but as chad said, 2 ways are practically lockers anyways. id probably be leaning towards a 1.5, but it depends entirely on how often itll see the street.
Damageinc,
Really depends on how quick acting the diff is. You can run a factory GTR diff that has shallow ramps and locks smooth and soft. A pleasure to drive.
Then jump in to one of the Nismo 2ways with a steep ramp and they lock with the slightest throttle or decel.
Then there's the preload.. For the street you really don't want more than 40-50lb where as the nismos for example are up around 70 so very tight.
Unless your running slicks or semi's you really don't need so much preload.
Damageinc,
ohk , ill just wait and see when my engine build is complete , see how it acts with the current lsd and then go from there .
i was thinking GTR Rear Diff from the beginning so...
cheers for the info :P
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
