Just wondering about my mags.
When we wash them and just spray on that McGuires(sp?) wheel polish stuff.. They come up really shiny but in spots have little .. blemishes I suppose you could call them.
Where can you get your mags cleaned... IF you can clean them with something to make them look like new. Haven't tried polishing them yet with a rub on polish ... I will do it one day.
But yeah.. Are there any places that "rejuvenate" mags to make them look like new??
Here is a pic of them. You can see the marks in the picture...
https://www.sau.com.au/forums/topic/2603-mags/
Guest Boxhead
i aint sure is this will help much, but when i have found to work the best, is ya know those cloth nappies, those nice white ones???
i wet those, and use a bit of the soap stuff you wash car with.. give them a real good wash.. then use that polish wheel stuff...
what it might be, is where you have sprayed on tire blackener or armor all its hit the wheel.. so you use the rag with a hand to protect the wheel from getting sprayed when you sprya tires.
https://www.sau.com.au/forums/topic/2603-mags/#findComment-47122
Its kinda hard to tell from the pic what kinda finish they are. Are they painted and clear coated or are they polished alloy ?
If they are polished alloy use a metal cut'n'polish type cream to clean them.
Or if they are painted and clear coated what may have happened is the clear coat has slightly peeled/cracked and let air in and oxidization has caused the blemishes, it will be kinda noticable cos the blemish will be under the clear coat and no amount of washing will get rid of it. You could cut and polish it till the clear coat is removed, but if this is what happened its better to take it to a mag specialist to fix it.
You should have mag repairers round your area somewhere.
https://www.sau.com.au/forums/topic/2603-mags/#findComment-47768
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
