Hey guys/girls,
Recently Sold my Skyline... All Left over parts I'm selling for cheap as i don't care anymore.
Prices are firm but if you think they prices are unfair, feel free to shoot me a PM and we'll discuss prices.
All parts Located in Melbourne Western suburbs - Pick up only. Will Post interstate at buyers expense.
Contact me via PM or text/call me directly on: 0421 205 751
2x Front TANABE SUSTEC DAMPER Shocks and RSR Lowered Springs for R32.
These Shocks are in excellent condition and are Damper adjustable. Only have the front 2 sorry. - $250
2x Front OEM R33 Shocks
In good condition, no leaks or rust - $200
R33 S2 dash surround
Perfect condition no cracks or broken vents. - $60
R33 GTSt OEM BOV
perfect condition - $30
R33 GTR OEM BOV
Gread upgrade for GTST's.. works fine - $70
R32/33 GTR OEM adjustable strut brace
good condition - $100
R33 S2 GTST drive and passenger seats
Both seats comes with rails. Passenger seat has no damage. Driver has small rip. (see pic) - $120 for the pair
R33 S2 Spoiler
White, No damages. LED tail lights works fine - $60
R33 Right had side tail light.
No cracks on plastic. Needs clean. Comes with working globes - $60
R33 Stock actuator
Works fine - $30
R33 S2 Manual Turbo ECU
Works fine - $50
R33 Dual pillar pods - suits 60mm gauges
Sits flush, goes form roof to dash - $50
R33 Stock Turbo
Comes with actuator and elbow - has around 1-2mm shaft play in and out. other wise, works fine. - $250
6x 480cc side feed injectors for RB25DET (not NEO)
Bench flowed, tested and cleaned - $500
R33 Clutch master cylinder
works 100% comes with original lines. Slave cylinder not included. - $50
Edited by Dush
https://www.sau.com.au/forums/topic/260308-skyline-parts-clean-out-melb/
  • Replies 51
looking at the sustec damper shocks, how much for shipping to NSW 2640?
and they will fit R32 gtst? and how low are the springs? im running on 18's and they just fit under the well on the stock shockers
Thanks mate
Just an update of the Parts that are still available:
R33 GTSt OEM BOV
R33 GTR OEM BOV - SOLD
R33 S2 Spoiler
R33 Stock actuator
Works fine - $30
R33 S2 Manual Turbo ECU - SOLD
R33 Stock Turbo
Everything has to go.. so inquire within. =]
hey mate
have you still got the spoiler??
thanks
The Spoiler and Dash surround maybe sold. Just waiting for the guy to pick it up... If it falls threw. I will post it back up on this thread.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
