hey guys i have some parts from a gtr ive seperated for parts for mine which i no longer need
genuine r32 gtr alloy bonnet some small dents really crappy paint easy enough to get perfect $350
passenger side r32 gtr alloy guard no indicator hole has some damage needs work $150
drivers side r32 gtr alloy guard with indicator hole great condition has a slight rub/scuff/dent $200
genuine r32 gtr grille great condition no cracks $150
genuine r32 gtr bonnet latch and support pieces complete unit $100 (needed to put gtr bonnet on gtst)
all parts located in toowoomba qld 4350 happy to freight if you organise the courier I DO NOT HAVE TIME TO GET FREIGHT PRICING
wrecking complete r32 gtr if you need anything else PM me
cheers
Edited by WHITE R32
https://www.sau.com.au/forums/topic/260311-cheap-r32-gtr-front-end-parts/
heres some pics...
the black guard is near perfect other than the light rub at the front of the wheel arch at the top (dusty as in pics)
and the grey guard is the one which needs work (bit wet in pics)... but been ally theyre easy enough to work with it has damage at the bottom near the jacking point from been jacked up but this is also easilly fixed and not seen because of the skirt anyway
neither guard includes the bracket that bolts onto the front as i need those
bonnet is rather good just crappy paint (wet in pics)
grille is perfect
Edited by WHITE R32
is the bracket the same as the r32 gts-t/gts brackets that u say arent included cos u need. its the little bracket near the head light right?
Do you have the diff? If so what do you want for it and can it be posted to Sydney? If its too much trouble dont worry about it, But I do need a diff soon!
Thanks
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
