Complete RB25 DET series 2 motor including all manifolds, turbo and loom. Motor came out a R33 which was crashed, Removed the engine to put into my mates S13 and before fitting to the S13 had the crank cleaned and linished and new main and big end ACL race series bearings fiitted. new gaskets (except head) throughout, timing belt and bearings done. New water pump fitted. Has been in the S13 for a few months now to run the fresh bearings in. Can see running in the car. Engine had done 114,000ks in the skyline and has only done a few thousand more in the Silvia. Motor runs great very smooth fresh motor.
$2700 for the motor Loom and Series 2 turbo
MINES ECU, was also in the R33 that was crashed, was making 297hp ATW on 12psi, A/F perfect on a touch under 12:1 right to redline have DYNO printout to prove.
$600
Will do the lot for $3100
Best if you call as this add is for my mate his number is 0450 052 809 (Shannon)
Also have alot of other 33 parts up for sale see my other add here
http://www.skylinesaustralia.com/forums/Wr...58#entry4452258
:banana::):D :D :D
https://www.sau.com.au/forums/topic/260318-rb25-det-motor-loom-turbo-mines-ecu/
  • 3 weeks later...
  • 3 weeks later...
There was 114,000 genuine ks on the motor when it came out of the 33 all still running perfect at the time and has done a few thousand more in the silvia since the freshen up and is all run and running perfect. Its my mates engine so give him a call (number on original post up top) and make an offer as he picked up his GTR last week so the motor is no longer any use to him.
Cheers
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
