Money needed to clear defects so spare parts are for sale..also wouldn't mind having a garage back again.
RB20DET Inlet Manifold $100ono
Comes with injectors, fuel rail, throttle body, tps, fpr. Came off of a running engine.
RB20DET Inlet Manifold $20ono
Top and bottom half only.
RB25DE Inlet Manifold $20ono
Top and bottom half on inlet manifold only. Selling due to upgrade.
RB20DET / RB25DE Exhaust Manifolds $20ono each
Standard manifolds to suit 20det / 25de.
RB20 Covers $10ono each
Standard covers.
RB25DE / RB20DET Fuel Rail $25ono each
Standard fuel rails to suit 25de / 20det.
RB20 Waterpump $40ono
Replaced 10000km ago, removed due to failing piston.
RB20DET Bare Head $100firm
Head removed due to failing piston. Compression was reasonable before removal (~140 from memory). Comes with values, valve springs and collets. No lifters. Can supply cams and bearings if needed. Can provide pics if needed. NO POSTAGE.
RB20DET Bare Block $100firm
Pistons removed due to failing no.5. Can supply crank, sump, pickup, bearing, sensors brackets if needed. Can provide pics if needed. NO POSTAGE.
Various Others $offers
Also have some various other bits and pieces (injectors, pistons, sumps, cranks, covers, cas, looms, piping, afm etc). Shoot a PM and ill get back to you with a price :banana:.
All prices are neg, not happy with the price, shoot me a pm with your best offer and i'll get back to you.
All parts located in Blacktown, Sydney. Inspections welcome. Prefer not to post but will at buyers expense.
https://www.sau.com.au/forums/topic/260338-fs-rb2025-parts/
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
