hey guys, I'm the one that did the tune.
We've left it pretty rough for now as the dyno run was only a power run, not a tuning run. I agree, there is a bit more tuning that needs to be done (In my opinion the curve is bad, and needs to be more straight, but nothing I can't handle). Its only been on the road twice for a couple of hours each so I didn't expect the AFR line to be too straight, but straight enough.
We gave up early because I did the usual tuning "tests" to see if there is a restriction.
1. Boost from 18psi to 20psi - 272rwkw to 278rwkw - Shitty gain
2. Timing - Increased timing on full load by 2 degrees - Power up to 281rwkw. Shitty gain.
3. More timing - No more gains AT ALL. Eventually, detonation
This leads us to believe that there is something stopping that extra power being made. You could feel it restricting somehow. Everything else is great though, torque curve is nice and straight, and consistant, power curve is about what you would expect with a 0.82 rear housing.
I'm making 314rwkw with the 0.63 rear, and most the the same, other gear. Here are the only differences (as per my 314rwkw run)
- Intercooler piping is bigger from the turbo to the hot side of the intercooler
- 0.63 Rear housing
- 225ml\min water meth nozzle (Mitch is running a 375ml)
- Larger q45 AFM
- Standard Intake Manifold
My car had the horrid 2.5inch cat on it when I did that big run.
I will say this though - My car has always felt a little laggy off boost. Nothing bad, just different from most other R33's that I have ridden in. This makes me think I may have cams installed. I do not know though. I'm getting that dreaded Exhaust side tappet cover leak fixed soon, so I might check then and see if the cams are any different to stock.
I'm sure we'll find what is wrong. Just a matter of trial and error.
Here is my cars dyno print out (same dyno) with a new fuel pump and a quick 1 hour road tune done all by myself and no driver.. (annyoing! haha)
Edited by The Mafia
  • Replies 44
trial error and head aches lol
cant complain really..i guess there is alot of people on here wishing they could make anything close to 280kw but i just got to crack that 300 mark....
i run a different setup but i use a greddy copy and make 500kw with no problem it is a bit lagger then the standard one but i did picked up about 20kw. fix the exhaust its a problem i had a 3 inch exhaust with a 3 inch gudded cat and the cat housing was the problem i changed to a full 3 1/2 inch exhaust and what different it made to the boost response it was like a new car. the cooler pipes, i have been there and done it didnt pick up any more power but i did pick up 200lb of tourqe. thats just my results from what i have done. good luck :D
Cmon Mafia, i though you'd have a spare boost gauge lying around..... just make up an adaptor for the O2 port and measure the Backpressure. Good tool to have in the tuning arsenal.
Gary
No probs, just use a silicon hose or something abit higher temp ..... its only in there for a couple of pulls , or runs on the street. Just give it abit of length to keep the heat from the gauge.
Been doing this for years, easy to catch dying cats with. Just did my own skyline recently, suspected dying metal cat, sure enough 7psi ! .. gutted it to get 3.2psi !
Just hook it up to a second map channel on the dyno and you can graph it along with the power curve.
Gary
fastrotor
thats a great idea.....will definetly look intot that.
mafia i got an old boost gauge i think and i can pull the middle out of an old o2 sensor and weld a fitting onto it to run a bit of heat proof hose to the gauge
Would be nice if cams were installed but I tend to doubt it as its near impossible to notice the loss of power down low until the cars noticeably caming over.
Chances are either cam timing is slightly off OR most likely its running a thicker headgasket or the motors running a lower static comp due to being previously rebuilt.
IMO :(
this is going to be interesting....
ok this is a stab in the dark...what if my cam timing was out by i tooth... could this be a possibility or would that show itself before the tune
hey thought i might post up the results of the back pressure test with the boost gauge on the dump pipe...
i have 5-6 psi back pressure..it really suprised me how much! will post the result after i fix the restricting cat......
waiting with baited breath....... :/ Hope YOU get some results....
my personal car was 7psi ! , gutted the magic cat, and dropped to 3.2psi ..... gain ? NOTHING. Hence why im still scratching my head....... Just plumbed in a 100psi stainless sensor via silicon to the turbo manifold to measure TIP..... Would know by now but unfortunately in my rush to change oil filter, i broke off the oil filter mount thread !!!!!!! Arrrggg....
Gary
hi fastrotor so you had no gains....dam...did you dyno it to check results or could you notice no gains driving around...i guess untill you have 0 back pressure still going to be a problem
I have the same sort of thing happening with mine
boost increases do nothing
14psi seems to be the sweet spot anything above that doesnt give you much more power
although i did find a big boost leak in mine which ive since fixed but havent run it on the dyno since.
the car feels different to drive so im hoping it makes a big difference
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
