tell your friends :banana:
Item:
White 1993 Nissan Skyline,
1998 RB25det Neo motor, out of an auto Stagea, has great compression and oil pressure
GTR bonnet ,
dmax front bar
GTR grill,
Trust side skirts and rear pods,
Four wheel steering disabled.
T04E turbo upgraded
just spent over $1000 on new manifold guaranteed to never crack,
HKS Style external wastegate with 8psi spring with screamer
HKS intercooler 3inch end tanks (silicone joiners),
custom intercooler piping,
Blitz BOV (plumbed back into intake),
550hp walbro intank fuel pump,
new tensioners and pulleys
MS air filter,
NISTUNE ECU, tuned by EFI Performance
DBA slotted front discs,
DBA standard rear discs,
Bendix ultimate front pads and rear pads,
Aftermarket camber arms,
Aftermarket castor rods,
Aftermarket steering wheel,
Boost gauge,
front and rear sway bar.
EL dial dash lights, Sunroof.
custom NPC clutch rated at 600hp
ohlins rear coilovers
apexi front coilovers
3 spoke rays racing wheels massive dish white centers,
25mm wider fibreglass front guards
Gold Coast/Bris
Item Condition:
awesome
Reason for Selling:
i want an s14a will swap for one of these only
she is a great car and will be missed
Price and Payment Conditions:
im after $15,000 ono for her or an s14.. she has had alot of work done from when i first got her and cleaned up alot
Extra Info:
i dont want to sell her just yet.. as i am booking her in for a tune in the next week or so... will want to sell after tune! she will definitely make over 300hp
Pictures:
will get a better pic of the engine bay
the car really stands out =]
Contact Details:
PM ME or in this thread =]
any questions just ask
https://www.sau.com.au/forums/topic/260340-eoi-1993-rb25neo-r32-gtst/
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
