Rb20 Rb26 And Rb30 Parts
Just clearing up the garage, parts no longer needed..
GTR injectors - $250
Gates timing belt (used) - $50
Rb20 turbo (stock inc water/oil lines) - $150
Rb20 gearbox - $500
Rb20 computer - $100
Rb20 wiring loom - $60
Rb20/25 high mount manifold (brand new - monster) - $200
Rb26 cam cover and coil cover - $100 (ready for painting)
R32 GTR front bumper (fibreglass) - $150 (needs to be sanded and painted)
R31 taillight (stove tops) complete - $150
Rb20 complete motor - $800
parts available for pickup - millpark VIC
hey bud
yeh ill part it for $1100,but im not sure about the freight u would have to arrange it from ur side.
keep in touch .
ronu
how much would you sell the rb20 complete engine, turbo, wiring harness, and loom all for???
how much would you recon frieght cost to perth???
 Share
    • I'm thinking that if it is struggling to make boost....the turbo is damaged.
    • I don't know. Look at the wiring diagram?
    • You can't do a really convincing examination of either the valves or the pistons (through the plug hole) with an endoscope. You can have a look, but it is difficult to see everything.
    • I mean, if the motor stock and you have a boost leak, (like a pipe has come off etc) you will barely able to move. I don't mean "drives like a 2002 corolla" I mean barely able to move the car at *all* That gauge is (mostly) normal. I say mostly because with a stock turbo and stock everything working normally, you'll hit that green line very easily/quickly. It's not like it will only finally reach there at 5000+RPM after slowly building to it. It it *does* behave like that, then you have a leak. If it doesn't, and the boost gauge is more or less pinned there any time you're on the throttle from ~2000rpm upward, then this is normal - the cars run 7psi stock. That's right between 0 and +1KG/CM (which is 14.22psi) If it's a manual, they do 0-100 back in 1998 of about ~6.1s to 100. The autos are about 7s.
    • I guess I just didn't think I would hear so much air movement and it being so loud, as it twice as loud as in the video above,  I understand how it works, but figured with the intake and exhaust all being connected to the air created by the turbo system, that I wouldn't hear so much of the air itself moving, as it would be going to the engine intake or out the exhaust. as far as I know I am making boost, it just doesn't feel like it is being used to increase the engine power or pull, maybe I am just expecting too much from a little 2.5L attached is the read out of my boost gauge during different stages:
