I seen a Maxima (something or other maybe a sports version of the TI) this evening and the sunroof looks a very similiar dimension / design to the *rear* sunroof of the M35 Stagea.
So I'm trying to find out if maybe it is the same as that way I can replace my sunroof rubber seal with one of them.
I know I could go to Nissan but you guys are more helpful than they will be (I think), but if not I will see just how good the local guys are here in Blacktown.
If anyone here works at Nissan Blacktown my apologies, no offence meant :)
Anyway, I will post any details I get incase anyone else here needs to replace an M35 rear sunroof rubber seal.
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/
Looking at FAST the J31 (Teana (Maxima)) and the M35 diagrams look different and I cant get a part number for the J31 anyway.
Did you give that part number I posted previously on here to Nissan? Try Hornsby or Lincorp?
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/#findComment-4469905
Stephen, as Timmeh said, try Hornsby or Lincorp (Parramatta Nissan), they'd probably be your best bet if you end up needing to buy through the dealer network. I know the Lander Group (in Blacktown) used to do import parts including Nismo stuff, but not sure if they do any more - they used to advertise in HPI magazine, even!
I'm gonna try and install FAST on my laptop sometime this week, will see how successful I am... :D
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/#findComment-4470093
I havn't used the part code with Nissan or anyone yet, it's not leaking water into the cabin so it's on the back burner for now.
It was only in passing a Maxima that I thought the sunroof window dimensions looked very similiar.
I was only thinking I could maybe get it cheaper if it was in Australia already for the Maxima TI range.
I will visit Lander when I get a chance and see what light they can shed on it.
Tah anyways!
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/#findComment-4470112
Ok Stephen, contacted Hornsby Nissan today gave them the part number in question 91246-AQ020 and they said can do at approx $75.
Dealt with a gentleman by the name of Mark Chin so when you are ready give 'em a call on 9473 7144.
Can't do much more for you than that!
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/#findComment-4471717
Thank you Timmeh, I really didn't expect you to go to the trouble of calling for me.
Tell you the truth I was afraid of what they would say the price was but $75.00 is pretty damn awesome, I would probably get them to fit it too so I can avoid any issues that I might come across. 'Cos it's the rear sun roof it disappears into the back of the roof when you open it.
I will give Mark Chin a call when I'm ready and get him to order it, will also ask him a cost for fitting it :P I don't mind giving the money to a dealership with a great reputation and most of you guys seem to swear by Hornsby Nissan.
And you could drive my car there and pay for it ;) But you've already done more than enough lol
Once again, thanks.
https://www.sau.com.au/forums/topic/260391-maxima-ti-specs/#findComment-4472038
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
