Prices are negotiable for quick and pain-free sales.
I will donate 5 dollars to SAU for each item sold except the airbox listed below.
This is also listed on NS.com.
GT30, RB25 rear, from HPinabox.com.
Internal gate, T3 flanged, Oil Lines to suit an RB20
$1195
6 Boost Hi-mount Internal gated, T3 manifold, from Sabbadin.
Used Gasket included.
Suitable for RB20/25
$995
Wolf3d V4, plug-in suit RB20/RB25, from Sabbadin.
$995
Dump pipe suit hi-mount stock rb20/25, from Sabbadin.
$200
Intercooler (slight damaged), came with car.
Piping to suit RB20, worked when on car.
$200
RB20 Turbo, from NS member.
T3 Flange, internally gate, no play.
$200
Airbox for NA Cefiro
$20
Contact Details:
Yenda
Please SMS during the day
Mob: 0400 927 884
Edited by psylnser
$1095
$895
$200
$895
$200
$200
$20
Contact Details:
Yenda
Mob: 0400 927 884
Edited by psylnser
$1095
$895
$200
$895
$200
$200
$20
Contact Details:
Yenda
Mob: 0400 927 884
Cooler has been sold
hey mate,
is the Wolf a v4 or V400?
does it come with all the software, data cables etc?
it is a wolf v4, i have the software for it. I do have the data cable which is rs232. however i will include the rs232 to usb convertor which is just plug and play and works automatically in XP.
!!!! PRICE CHANGE !!!
$1095
$950
$200
$950
Buy the GT30, Oil lines to suit, manifold, dump pipe and wolf computer to suit rb20/25 at discounted price of 2900!
$200
$20
  • 3 weeks later...
FREE COURIER TO YOUR DOOR FOR PRODUCTS OVER 200!
$1095
$950
$200
$950
$200
$20
Edited by psylnser
$950
$200
$950
RB20 Turbo, from NS member. Turbo off laurel - possibly sold
$200
$20
Edited by psylnser
$1195
$995
$995
$200
$200
$200
$20
Contact Details:
Yenda
Mob: 0400 927 884
gt30 turbo sold
rb20 turbo sold
intercooler sold
wolf3d sold
6boost sold
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
