I have finished stripping down most of my RB26 donor engine rady to build up the B30.. I noticed when I took off the Oil filters there is a slight difference between the RB30 and RB26 block?? My RB26 is from an R33 and has a water cooled oil cooler that the filter then mounts to. On the RB30 the filter is direct onto the block. When you remove the cooler from the RB26 instead of having a thread, there is a lug sticking out that is a snug push fit inside the oil cooler housing (I assume this is to direct the oil flow correctly) How do I modify my RB30 block to accept the same cooler or is it easier/better to dump it and get a relocation kit and traditional type cooler? I am sure I have seen RB30's with the RB26 type cooler so presume it's possible?
Thanks
Lee
yes it can be done, i just unscrewed the fitting out of a rb26 block that has the slot in it for the oil cooler block and used that to screw in the place of the threaded one on the rb30, it screws straight in and works same as rb26. To get the 30 one out i ground a straight into it with an angle grinder and used a thin bar to unscrew it (was damn tight, might need to heat it with any oxy to crack the seal if its really tight), the rb26 one already has a slot in it so use a piece of bar that will fit in it and do the same.
what doesnt work? do u mean pushed as in making alot of power? ive never had an issue yet with mine, i have removed it from my other motor but redoing all the water lines etc under the plenum is a pain, well harder than just screwing the rb26 oil cooler on anyway. whats a gts4 one look like?
Edited by unique1
im mean when your thrashing the car they do sweet fa in cooling the oil.
the gts4 one is angled to suit the front diff. and when a sandwich plate goes on its much easier to work with. but you will need the 26 block fitting.
basicly the same but without all the hoses and cooler in place..
fair enough sounds like a good idea i didnt even know about the gts4 ones, thanks for the info
cheers for the info guy's I have to say when looking at the blocks I thought the stub in the middle must be removable.. So I have two options.. Well three... RB26 oil cooler which I can see probably does jack if you are really giving the car death.. GTS4 cooler.. Is it an air cooler or water cooler?? I wasn't clear on that.. Finally get a relocation kit and fit a regular oil cooler.. I presume a 19 row regular type rad cooler would be fine for a start?? I don't intend doing heavy track use at all.. just a road toy if that helps!
I was also planning on removing some of the other junk under the inlet plenum while I am at it to tidye tings up a bit.. I hear the Idle valve can be removed and then it's a cse of joining some pipes and blanking others..
By the way T04GTR.. What is the car in your avatar?? I can't make up my mind!? looks like a beast anyway..
DR30?? I am guessing that is a very early liner?
Anyway. When you say the relief valve in the block I oresume you mean the bit that looks like a ball bearing? I wouldn't have enven considered removing it!
So basically it's a sandiwch plate of some sort and relocation kit or cooler kit.. 19 row not worth bothering with?? Only ask as they seem to be very common and easy to obtain!
Thank you
Lee
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
