Gibson R31 and Gibson R32 on track with no other traffic (well, there was an R35 somewhere in the mix) to muffle their sounds.
What a fantastic day of spectating.
Once again Boz, thanks for starting the thread, much appreciated :(
  • Replies 52
Posted Images
Is this Dave Nolan??
18's is fast for a standard full weight road car . I would like to see what your standard civic does haha
The GTR did a 2min24 around Bathurst in standard trim. It could actually stretch its legs up there. The fastest IPRA is a 2min28 LOL
a guy i work with was telling me about this on tuesday.
his name is Brett, do you remember talking to him also John ? he said his brother owns the r32 , i just dont know his surename, so it could be Ashwood for all i know, i'll double check tomorrow at work
  • 2 years later...
Does anyone know who won in lap times the winfield gtr or the R35 GTR, I cant beleive no one has asked this? ANd what the hell does 18,s mean or 17s mean. Cant a simple best lap time for the winfield gtr and a simple lap time for the r35 gtr be posted up?
Well doing some research On the bathurst track i seen that 2:12min was the record for a R32 GTR back in 91/92 I think i saw tat a stock R35 did it in 2.25min.
records for v8s are:
The lap record for the race is the 2:08.4651 recorded by Jamie Whincup in his Ford BF Falcon in 2007,[1] not to be confused with the fastest lap ever recorded, a 2:06.8012 set during practice in 2010 by Holden driver Craig Lowndes.[2]
But i wonder with all the new technology now modding an r32 GTR would even challenge todays v8 Supercars.. AMAZING
Edited by GTRAAH
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
