I don't know the cost as I haven't had any done, but the eyebrow height is the height from the centre of the rim to the edge of the guard. Because the fibreglass guards have a different edge position that is why they need to be engineered.
i have heard of this a few time
people can get things engineered but still been sent to regency
the popo said "you could have modified it after it got engineers approval"
which to me is just plain bullsh*t but had a mate go through regency even with engineers certificate of approval
In a cops defence, if he hasn't received necessary training, he is better off sending it to get checked than him ok it himself, then the driver hits a pedestrian and a fibreglass shard kills them, or something else. Refer to defect thread for more discussion. But i do agree that if you carry the necessary paperwork, you should be ok. Mind you, there is little evidence you can show to prove you haven't tampered with it after the engineer has certified it.
No thats true... but cops are finding you GULITY until you can prove yourself INNOCENT...
Isnt it meant to be the other way around??
In that case, i believe that if you were to be defected for the ADR approved bonnet, and that only, the regency fee will be waived, as long as it does comply with ADR's. However, regency might comment on your low ride height or loud exhaust, which you will have to fix and return, at a fee....
Sorry, don't wanna turn this into another defect thread.
your pretty much on the right track there damo
i think that if you do have everything engineered and then get picked on
then the inspection fee should be waived and you would therefore be compensated for your troubles
Edited by Krishy
This topic has been covered 1,000 times before. Please use the search function instead of making a new useless post. Or better still, download the SA/ADR rules and find out for yourself, or even better yet ring Regency and ask them yourself. Don't rely on 2nd hand information is my advice.
regency will only approve of engineers certificates from a couple specific places, otherwise they can reject it. i cant remember which those are so ring em up and find out.
they can try, but they can't do it legally; all it needs is a court case to prove that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
