hey all ive gota boost leak in the 260. i blocked the BOVS (under my battery) for a bit of shits and giggles when i got the bar replaced and ever since then i have a this weird boost leak from 3 grand upwars, its hits fairly loud at 3 grand and sliughly increases as it gains rpm. :D i just CANNOT find the bastard! any hint or ideas on how to trace it back. im guna completly pull it out and put it back togeather sum stage this week...
https://www.sau.com.au/forums/topic/260483-boost-leak-i-just-cant-find/
Oh the joys i had the same damn problem.
Why did you block the BOVS off? the factory ones are some of the best out there?
I did it in 2 ways, a can of carby or throttle body cleaner, spray it around hoses, gaskets etc while the engine is idling, the engine revs will rise or drop if you hit the spot.
The other way was to remove the afms and pressurize the system, as in get a air compressor set the regualtor real low and blow compressed air into the intake system, you should hear the leak.
check turbo to manifold gaskit... had same problem in my silvia, after ALOT of searching, couldn't find the leak anywhere in the pipes, checked the turbo and BAM! nuts were loose. nipped them up, problem solved.
D.
hey all ive gota boost leak in the 260. i blocked the BOVS (under my battery) for a bit of shits and giggles when i got the bar replaced and ever since then i have a this weird boost leak from 3 grand upwars, its hits fairly loud at 3 grand and sliughly increases as it gains rpm. :( i just CANNOT find the bastard! any hint or ideas on how to trace it back. im guna completly pull it out and put it back togeather sum stage this week...
" i blocked the BOVS (under my battery) for a bit of shits and giggles_ and ever since then i have a this weird boost leak"
I think you answered your question with that statement. I would start there champ.
Edited by rb30dett
