ok so i'm looking at buying a car, apparently hasnt been started in 2 years as he has both a better weekend car, and a company car as a daily.
he says it will need all new oil and fluids etc, new battery. now all the fluids i can understnad, BUT, he lives pretty far from me, and i wanted to just take a battery to get it going.
i asked if he would change fluids etc at my cost just to get it running for me, as i didnt want to go to see a car thats not running, but hes pretty busy and doesnt have the time to do it. fair enough, as i do believe he is genuinely pretty busy.
now, i want to take a battery down there just to get it started and going, with the old fluids in it. now i thought that oil doesnt just 'go off' over time if its just sitting there, but not sure on this. are there any dangers in starting it with old oil in it? i'm worried it might start knocking and him saying its my fault for starting it with the old fluids in it or similar.
the other danger is i get it home, change fluids, its still rooted, and he says its my problem.
question is, is it safe to start it on old fluids? i was just going to take a battery and some basic tools. pull the plugs, crank it to prime it/build oil pressure, then start it normally. thoughts? ideas?
cheers,
Ben
https://www.sau.com.au/forums/topic/260496-car-hasnt-been-started-in-2-years/
if he doesnt mind change the fluids there
2 years is a long time...
oil is very easy to do as with most fluids.
If thats still no go i would seriously think about getting a flat bed to bring it home.
LAst thing u what is the oil that has already broke down or coolant thats all brown and dirty... usually its 6months or 5000km for a performance car
or normal car is 12 months or 15 000 - 25 000 .
thing is, i've never really seen a mechanic do a service after a given period of time, they all go off km's.... thats what i've seen anyway
does oil actually 'go off' over time?
and yes i was going to crank it without starting it to build oil pressure
flatbedding it home isnt going to happen. 1, he lives too far from me and 2, if it is f*cked, i wanna know before i buy it, not when its in my driveway
Taken from ironchefimports.com;
drive your new car like a granny until you can put a fresh tank of 98 octane in it. After a couple of weeks, fuel starts to drop octane, and I can guarantee that any fuel left in the car will be totally stale, so no thrashing or you may wind up with a dead motor!
As said before, just remove the plug to the CAS and crank it over to build pressure, saves pulling all the plugs out.
I'll be in the same situation as you soon, my car has only been started once in about 2.5 years and i'll be changing all fluids and the spark plugs. Last time my car was started (first time in probably 8 months or so) we jump started it, started first go and was running fine, then noticed fuel was pissing out at the back of the car. Turns out one of the fuel lines had perished and dryed over time and with the pressure in the lines when the car was running caused the line to split... So that is something to keep an eye out for once you get it started!
It was really annoying for me, as i was meant to be moving the car to my friends garage, but since i was flying to QLD the next day to live i had to leave the car outside at my grandpa's house... Damnit! :/
Make sure you get it cheaply. If he cant demonstrate that it runs and drives properly - assume it doesnt and pay a price that reflects. I'd be worried stuff like brake cylinders will have rusted up, so make sure you have extra cash to fix stuff. Cars dont really like sitting idle.
the fuel will be totally stale. had my car sitting for about 2yrs and I went to start it one day but forgot about the fuel and it ended up fu*king up my injectors. Clean the tank out and put new fuel in it then take the feed line off at the engine turn the key and let it pump any thing out of the fuel line. I had to get my injectors cleaned and thats not cheap.
Another thought, after two years, won't pretty much all the oil have drained into the sump? I'd be concerned about metal/metal contact when i started it.
Correct! The first 3 sec can be murder.
You can pour in a little oil at the top before starting. But better still, do an oil change on the spot and another in 3-5K depending on colour.
Earlier post correctly mentioned coolant/water to be changed asap lest there be the beginnings of corrosion (radiator, heater core etc).
What i'm going to do when i first start my car after 2 + years is dump all the old oil, pour a full bottle of some cheapo oil and just let it all drain straight out, sump plug back in and fill it with some quality Royal Purple oil... Should do the trick.
ok i'm starting to worry now. my liner sits in the garage for up to 3 months without starting but services are all done on time(every 6 months ect.) since i dont even come close to doing the Ks.
i dont disconnect the CAS and crank it i just jump start it and off i go.
any feedback?
any feedback?
No worries!
Just add a little oil at the top before start-up. It's preferable that you use high quality synthetic in the engine & same one for top-up.
And perhaps a bit of trickle charge for the battery.
any feedback?
3 months isn't too bad - but you could always disconnect the CAS and manually crank it over just as a precaution.
No worries!
but if i keep topping up the oil i'll end up with ecess oil which is also not too healthy for the motor?
please elaborate on this manual crancking?
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
