Putting up my r32 for sale.. owned for about 5 years. Not entertaining offers, I doubt you can find an rb25 powered r32 for this price anywhere in Australia. Almost giving this away, but have my eyes on something else at the moment.
I really haven't had much time to work on it over the last 2 years, but still running very nicely. Really best suited for a potential track car, or a weekender.
1989 R32 GTST
RB25det
Highflow rb25 turbo
RB20det gearbox - should be good to about 200rwkw, after which you'll probably need to put in an rb25 one.
Full 3" exhaust from turbo back
Cusco strut brace
Whiteline springs over Bilstein shocks
Hicas lock bar, all HICAS removed
Xtreme cushioned ceramic clutch
Xtreme lightened flywheel
Nismo adjustable FPR
GTR fuel pump
GTR BOV
GTR aluminium bonnet
4.3:1 LSD
DBA 4000 slotted rotors front
RB74 pads front
Braided front brake lines
Braided clutch line
400x350x75 intercooler
V35 Skyline Rims (17")
Full alarm & immoboliser, remote central locking
Tinted windows
JVC mp3 player
Focal splits front
Included (needs to be fitted, sprayed):
Genuine GTR front bar (plastic)
GTR grille
GTR reo/support bar
Type-M side skirts
Whiteline adjustable sway bars front and rear (new in plastic)
Rear braided brake lines
Problems:
- Aircon doesn't work. Fitted with supposed working replacement compressor, but never been converted to Australian compliant gas. For track dunga might want to remove it anyhow.
- Clear from roof starting to bubble slightly (shown), although in general paintwork pretty good for that age
- Small dent passenger side (shown), and couple of other small ones. nothing that couldn't be fixed pretty easily
- brakes are a bit spongier than they should be (master cylinder?)
Has QLD mod plate for engine conversion, manual conversion, intercooler, and larger turbo. Has been driven very little over the last couple of years, garaged 98% of the time. Have replaced many gaskets, hoses, most bushes, etc during the conversion. Currently running stock RB25 ECU, however RB25 PowerFC is plug and play with loom (tested). Add a boost controller, get a good tune, and should see over 200rwkw. Is a little rough around the edges, however would make an ideal track, or occasional road car
Is currently QLD registered, but will sell unregistered and drive it to your place and remove plates, unless you can point me in the direction of somebody for a friendly safety certicate. Most obvious things should be fine such as lights, wipers, tyres, no oil leaks. If no interest will tidy it up and sell for a couple more $k later on.
$6500 without bodykit parts as is
$7300 with bodykit parts
+$1000 with powerfc and hand controller
Will not separate parts until sold
I'm on the goldcoast
https://www.sau.com.au/forums/topic/260546-r32-gts-t-with-rb25-goldcoast/
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
