Munch And Sip V4 Afternoon Cruise Saturday 28th Of March
hoony
 Share
hey folks,
once again it's time for another Munch and Sip cruise
it will be on;
SATURDAY THE 28TH OF MARCH
the exact time is not yet known as i'd like an expression and show of hands as to WHAT time would be suitable as well as what type of cruise people would like this run to be
traditionally i have a coastal, highway and freeway map combined but would like some input as to where some people might like to go, even though the maps have worked out really well in the past i may change some things around to make this one a little bit different
and as usual, we will be stopping by my sister's shop for lunch but this time there will be enough chairs and tables so we can actually sit down and eat (the shop isn't made so people eat inside but for us this has to change!!!)
so yeah she'll have on offer the usual Chicken Kebabs, Roast Beef/Pork and Gravy Rolls and all that other jibber jabber stuff as well as the very well loved BUBBLE TEA!
so mark your calender for this event and i'll get back to everyone asap on a particular time that suits the majority of all
please post your interest on here as it would help out my sister a little too!
cheers,
Andrew
  • Replies 79
her shop is in Koondoola which is surrounded by Mirrabooka, Alexander Heights, Girrwawheen and is in between Beach Road and Marangaroo Drive (Off Mirrabooka Avenue)
don't worry, if you live too far North or South i'll cater for that too so you can leave where you wish but i usually end the cruise somewhere central so it's fair for everyone
Andrew
No need to check the calender woman. Were going!
I really enjoyed the last one ya did Andy.
MMMMMMMMM Roast Pork and Gravy Roll
Love the tunnel runs too Andy. That is a must do!!!!!!!
:( Looks like we will be there. :P
wats a butt bokker
Hahaha.... I call her Chikkie babe and the bokker is in reference to the noise a chicken makes, you know.... Bock bock.
And butt is her arse..................
ROFL ROFL ROFL nice comment rob
hey andy might be there depends if i can get alix out for it car is not far off but just not yet and ill try get a coral shirt for the day can u hook me up just get 2 and sew them together :cool:
Nick, Bretto, Allen and Marianne... good to hear you guys are coming out again! food will be great as usual except this time we'll all have somewhere to sit! hahaha
Robert mate if you can come out it would be great, good fun
the other Nick, yeah mate Bubble Tea as usual but if you want i can get them to make you Chendol or Ice Kachang or whatever, just let me know and i'll ask
LOL Scott, wear a coral/salmon shirt if you want, i'll probably not wear mine seeing as though what happened to me last time hahaa
and Brenden, what time do you work?
and Paul, i have to stop trying to run your VII... until i get more mods lol
anyone else?
as mentioned before, more specific details will be posted up shortly!
Andrew
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
