Munch And Sip V4 Afternoon Cruise Saturday 28th Of March
  • Replies 79
haha thanks Brendan
and Rhys, her shop isn't open Saturday's but i'll make her open for the two hours or so so she can satisfy our hunger :/
and Brendon, i don't think i'll be able to make the cruise before or after you finish work unfortunately, unless you take it off? :)
I noticed you asked for ideal times. I dont think you will be able to please everyone, there are quite a few who work on saturdays.
I think the best thing to do would be to organise it so that we hit your sisters shop for a late lunch say around 1ish. However the times work out will depend on your course. I think you should make the time, then let everyone know so they can start planning, requesting time off etc. :wave:
andrew i mite not have the 32 back from the painters so i may have to dust off the tonner and show you the old girl lol the car that is lol
if its ok to be see there lol
Edited by 350tonner
LOL i got your message man, i don't have any credit so i couldn't message you back, was wondering who it was LOL
OKAY EVERYONE TIME IS READY!!!
12:00PM MEET FOR A 12:30PM LEAVE... CRUISE SHOULD FINISH AROUND 4:00PM BUT OBVIOUSLY A LITTLE BIT OF THIS AND THAT CAN CHANGE, HOPE TO SEE YOU ALL THERE!!!
WE'RE MEETING AT SOUTH STREET PARK AND RIDE BY THE WAY, IF SOME FOLKS NOR WANT TO MEET AT CITY WEST THAT'S FINE, RHYS WILL LOOK AFTER THAT I'M SURE AS HE OWES ME AND NORMAL MEET AS MENTIONED UP TOP, 12:00PM MEET AT CITY WEST
guess ill try make an apperance lol been cruising wit u andrew but bubble tea has my intrest i have no idea what it is lol ill try talk alix into it the old git is getting a bit shy in his old age
How far into the cruise do we hit ur sisters shop man?
I have alot of assignments to take care of around that time, but i dont mind heading up to get a bite to eat if the shop meet point isnt too far near the end of the cruise...?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
