Hi all,
I finally got all the parts I need and the new turbos in, now its time for a tune.
Been searching on the site and everything suggest that I should either choose Croydon or Unigroup, of which I have chosen Unigroup for the tuning.
Also seen some prices on here and by the looks of it a full tune will average around the $500 - $600 mark, not sure if I'm right here.
Well i called them up today to get an estimate of a full tune and installing some HKS cam gears and was quoted $1200, saying that the cam gears will cost about $300 to install and dial in.
Now is this about right? from the prices I've seen this seems a lil pricey, or am I wrong?
Forgot to mention that I'm running a PFC
Edited by Mr Cali
  • Replies 46
dialing in the cams properly is a time consuming process, make an adjustment, tune, power check, repeat until no more gains, x 2 for two cams and you get the idea. I have spent 1500 on tuning and about to go another 500 to perfect so 1200 is good price. 600 would be a very basic tune at 160 odd an hour from scratch
HUGE recommendation for Yavuz. He tuned my GTR about 2 weeks ago, and i was very impressed with what he acheived in such a small timeframe. Ask him to show you "steve white rb30gtr with microtech/autronic"'s graph, you'll know what I and others on this forum mean :D
Back in the day when I had my first tune done, full PFC tune from scratch, boost set, cam gears dialled, from one of the best GTR tuners in OZ. Was $800. And its perfect. My cam gears were already installed but thats seriously a 30min job.
I reckon $1200 is overpriced.
If you want a tune that you don't have to ever get looked at again that is pretty much near perfect in any way then pay Yavus the $1200 and get it tuned. He does not have time for time wasters who complain about price.
The guy is a engineer who happens to be a car guy, he could be doing a million other things making a monsta of cash without even having to touch a car but his service comes with a price tag and I think its worth it.
If you don't think its worth it then don't waste his time.
Some of the best tunes I had on my GT-R were no more than $600 for a power FC.
That included dyno printout etc... Never had any problems, this was a couple years ago, don't know if prices have doubled, $1000+ for just a tune on a piggyback like a power FC is a little excessive, it's not a MoTeC.
power fc is not a piggyback mate, they take your factory ecu out and replace it, it is a standalone ecu and therefore it, by definition, cannot be a piggyback, which intercepts and manipulates signals sent from the factory ecu.
At the end of the day, if you aint happy with the price, take it elsewhere, this guy obviously has a reputation for doing great stuff and I am sure he is booked out in advance so he aint gonna miss your 1200
Edited by R33GTRKid
Im sorry but there are alot of tuners out there that would consider themselves good at tuning, paying $1200 is a lot of money especially compared to NZ where the most expensive place I know of is $800NZD for a full tune... considering Australia most likely has more tuners to choose from I'd assume that would bring the price down or this Yavus guy is a whiz kid that has prooven his tunes are better than everyone else's..
Im sorry but there are alot of tuners out there that would consider themselves good at tuning, paying $1200 is a lot of money (I can understand no-one likes the feeling of being ripped off) especially compared to NZ where the most expensive place I know of is $800NZD or the more reasonable places 500-600NZD for a full tune... considering Australia most likely has more tuners to choose from I'd assume that would bring the price down or this Yavus guy is a whiz kid that has prooven his tunes are WAY better than everyone else's..
Installing cam gears is no 30min job. You have to remove the CAS, timing belt cover, all the guff associated with getting the timing belt off, then swap the came gears, replace guff and timing belt. Then adjust the cam gears a number of times to get power spread right. Then once you are happy with the setting and tune complete you need to again remove the CAS, replace the timing belt cover (put back on) then re-install the CAS and again check base timing.
Not hard work but time consumg work. Sayings its a quick and therefore cheap job is wrong. Workshops charge for their time and little time consuming jobs are by nature expesnive. Its a shame but it is what it is
Exactly, setting up the cam gears is where the money is, say $700 for the basic tune, $300 for ditting the camgears and $200 for tning to suit, it requires multiple power runs and every time you adjust the exhaust cam it is a 15 minute job, then trim the tune to suit . Do you also have a boost controller that needs setting?
But how do you know it was a good tune?
That's the question of the day :(
You could put two cars together and one drives better, and so on. But being you only drive your own car regularly its hard to say what "is" good and what "is" not.
300 to install cam gears?! You dont even have to take the belt off, just the CAS and top cover, slip them in while holding the belt...its not hard.
At the end of the day, if the driveability is as good as, or better than, a factory ECU, is responsive, economical, has no hiccups or flat spots and makes target power for the setup then its a good tune.
My mate (a forum member) had his PowerFC tuned twice in the space of 2 weeks at $600 a pop.
The first tune was absolute rubbish, even when they tried to fix it, the car ran okay but guzzled fuel like it was 60c/L. The second tune was much better but he didnt make the power he hoped for - $1200 later and he still doesnt have a tune he is overly happy with.
On another note, installing cams/gears is a process where a mechanic has had past experience in dealing with, he will know where they are to sit to get maximum gains because he would have done hundreds of them before and seen all the different combos so you're really only paying for their labour to fit and do small adjustments. There is no way they actually start from scratch on every cams/gears they install on an everyday setup.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
