its quite hard to get an estimate for a price of a tune because there is an endless continuim of tuning quality. at the end of the day your better going to a reputable tuner who you trust not to rip you off.
Also another point is that tuners save the calibrations of EVERY car they tune along with a full set of notes, so as much as youd like to believe your getting a tune from scratch, often tuners will find a previous calibration and start from there, which saves time and hopefully money.
I cant say ive heard of microtchs going out of tune, sounds strange. perhaps one option would be to save your calibration on your computer so you can reload it to the microtech everytime the car doesnt run right.
also its a good idea to run an O2 sensor, especially a wideband, so the computer can run closed loop, as its often more economical and smoother running when cruising
  • Replies 46
N1GTR would you mind enlightening me on how that was possible?
And yeah had it been me (who wouldn't have gotten a Microtech in the first place), Id've gotten it tuned with an 02 sensor of some type. Apparently they can be tuned to be as economical without though, but I'm not sure.
Edited by bozodos
i know i was getting a tune from scratch. first gtr on a wolf v500 that my tuner/mechanic had done.
but you are correct. and in a lot of cases this is a very good idea. it's basically the same as having a base map like a power fc etc.
Its not a good idea to tune with 02 sensor feedback on, as it will always give you varied results and the ECU will be constantly correcting etc, its nasty, if you know how to tune, you can get good economy and smooth cruise without closed loop.
If i could remember, i would
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
