i've got old-style AVC-R and S-AFC and an HKS fuel-cut defender, and i'm looking to tune the suckers a bit better... car runs *okay* but i cant help thinking i can get more out of it.
i want to run about 10-12psi boost (standard turbo/cooler), so does anyone have a decent S-AFC map i could use??? or is just the standard fuel map adequate for running that sort of boost? also, how do i throw the FCD into this equation?
with the combination of avc-r, afc and FCD, i have a feeling that either a) my injectors/fuel pump are not stock or B) the owner of the car before me was a rich rice-boy with no clue and would have driven the car to an early grave by cranking up boost and fuel beyond the cars capacity... which brings me to my next question. is there any easy way of telling whether the injectors are stock?
answers to these questions would be awesome.
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/
grimr33per,
in regards to tuning the s-afc would it not be better to tune YOUR car on a dyno? Every car is different....had a different history, slightly different mods etc etc and therefore someone elses map may not work as well in your car. If you really can't afford the dyno costs I guess using a map off another car is better than nothing....but IMHO I'd rather save the dough and hit the dyno....
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/#findComment-552255
no probs man.......can't recommend any dyno's in brissie as I'm from Melb!!! In regard to dyno costs.......shops usually charge by the hour for a dyno tune and therefore depends on how much work they need to do....allow for anywhere between $200-600.
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/#findComment-552265
You can road tune an S-AFC, but you probably won't get the optimal power out of it. You just have to make sure you don't run it too lean. But if you can get it done for $80, don't waste your time doing it yourself. $80 is nothing, I paid double that.
Also grimr33per, all those mods are fine to run with the stock fuel system, so don't assume that your car has bigger injectors. My car had a similar setup and managed 214rwkw before leaning out. You pretty much need those mods *before* you bother with a bigger pump or injectors, so the previous owner hasn't just riced it up.
Edit: as for identifying the injectors, I haven't had a good look at mine yet but I think they don't have red/purple tops :P Also if you have a custom fuel rail for top-fed injectors they aren't stock.
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/#findComment-552391
I have a T04E. Flows a little better and can run higher boost than stock due to steel wheels but as such suffers from a bit more lag (it's really not bad at all though). In theory I should be able to hit 250rwkw with it but I'm not too sure the exhaust housing is big enough in its current form.
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/#findComment-552447
I got it done at Procar Dyno in Cromer Heights (Nthn Beaches) Tel: 99815099
you should be good to run 12psi on standard pump with standard computer, but when i fitted my 2530 i was running lean on 12psi. anyhow you will be able to tell whether or not when its being tuned on the Dyno
https://www.sau.com.au/forums/topic/26062-s-afc-fuel-map/#findComment-553341
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
