Advice Needed From Someone With Tuning Knowledge
shotter
 Share
I got my car tuned a few months ago with a haltech intercepter and the temp that day was around 40deg. The car was running fine untill a week ago. Now when you rev a gear out it starts to pull then it has no power, It feels like it just cuts off. I was wondering if because now the days are around 25deg would the air be colder/denser and it's leaning the mixture up causing this problem? I have also noticed that the exhaust out the back is hotter than i remember.
Thank You
no. your fuel pump is no good. or its supply. stick a guage on it and take it for a hit. deffinatly nothing to do with the tune..
mine was done in similar heat. no drammas at all in freezing gouburn
But it's a new pump. And sometimes it will run fine and other times it will play up. i usually find it will play up in 3rd gear.
Could just be over boosting abit in the cooler air and hitting the boost limit .... have you noticed the gauge when driving being a tad higher ?
If you have access to the boost controller / bleed valve etc , try turning it down abit to see if it help.
Gary
Edited by Fastrotor
Gary
I have a EBC and it isn't spiking. I holds boost perfectly
But do you know what the cut is set at in the haltech ? perhaps it was set too close to the mark, and the difference isnt noticable to you on the gauge ? Can't hurt to try turning it down a couple of pound just for a test, if you've run out of other things to try that is.
Gary
Gary
It will even play up on 6psi
How are you testing the EGT? Any chance you have a leaky blow off valve or some other intake leak forming?
ok i take that back. It's still doing it just not as bad. Im wondering if the base timing is too advanced. Will it cause this problem? i think it's around 20deg BTDC.
I replaced the fuel filter a few months ago and the compression is fine. I went back to the workshop that tuned my car and as usuall they were useless and rude. I decided to drop the base timing back alot and now the car doesn't play up.... it idles really low now but i will adjust that soon.
ok i have set the base timing to 15deg with the TPS cable off. I noticed that the timing jumped up a fair bit when i pluged the cable back in but i guess that is pretty normal. But driving it after that it still feels like the power cuts as you rev out the gears. The only other thing that im wondering is i have heatrange 7 spark plugs in there and the std coils. Now i dont know much about exactly how the different heat ranges affect different things. I know that when its cold it runs like a dog thats fine but should i go back to heatrange 6 plugs till i get splitfire coils? Or could i just be barking up the wrong tree?
But thats the problem. I have taken my car to 2 performance workshops before and paid over $2000 and they were useless. It's hard to find a good workshop in canberra
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
