I got my car tuned a few months ago with a haltech intercepter and the temp that day was around 40deg. The car was running fine untill a week ago. Now when you rev a gear out it starts to pull then it has no power, It feels like it just cuts off. I was wondering if because now the days are around 25deg would the air be colder/denser and it's leaning the mixture up causing this problem? I have also noticed that the exhaust out the back is hotter than i remember.
Thank You
no. your fuel pump is no good. or its supply. stick a guage on it and take it for a hit. deffinatly nothing to do with the tune..
mine was done in similar heat. no drammas at all in freezing gouburn
But it's a new pump. And sometimes it will run fine and other times it will play up. i usually find it will play up in 3rd gear.
Could just be over boosting abit in the cooler air and hitting the boost limit .... have you noticed the gauge when driving being a tad higher ?
If you have access to the boost controller / bleed valve etc , try turning it down abit to see if it help.
Gary
Edited by Fastrotor
Gary
I have a EBC and it isn't spiking. I holds boost perfectly
But do you know what the cut is set at in the haltech ? perhaps it was set too close to the mark, and the difference isnt noticable to you on the gauge ? Can't hurt to try turning it down a couple of pound just for a test, if you've run out of other things to try that is.
Gary
Gary
It will even play up on 6psi
How are you testing the EGT? Any chance you have a leaky blow off valve or some other intake leak forming?
I replaced the fuel filter a few months ago and the compression is fine. I went back to the workshop that tuned my car and as usuall they were useless and rude. I decided to drop the base timing back alot and now the car doesn't play up.... it idles really low now but i will adjust that soon.
ok i have set the base timing to 15deg with the TPS cable off. I noticed that the timing jumped up a fair bit when i pluged the cable back in but i guess that is pretty normal. But driving it after that it still feels like the power cuts as you rev out the gears. The only other thing that im wondering is i have heatrange 7 spark plugs in there and the std coils. Now i dont know much about exactly how the different heat ranges affect different things. I know that when its cold it runs like a dog thats fine but should i go back to heatrange 6 plugs till i get splitfire coils? Or could i just be barking up the wrong tree?
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
    • ECUMaster is an Australian company from memory, been around a while, and seem to actually play really well on more unique engine setups. Seems to be more of them being used in the states, and they seem to support more cylinders than most others.   My opinion on stock ECU/Nistune with he AFM, is you can tune around the issue of stalling. It's still a bit of a band-aid, and not the most perfect smoothest setup, but it can make it drive able and not an absolute PITA. But you're still compromising. A vent to atmosphere BOV has the same issue as no BOV with regards to the AFM. Both make the ECU think more air is entering the engine than there really is. And I can't find any hard science/decent evidence that supports the claims all the "you MUST run a BOV of some sort of you'll blow the turbo up". About the only one some people can give of why is "lag between gear shifts", and that is only an issue when your boost source for the waste gate is pre throttle body. I ran my boost source for the TD07S off the inlet manifold. Didn't have weird boost spiking issues, didn't have boost control issues, and on a gear shift the wastegate slammed shut, which meant all exhaust gases would be keeping it going round and round and not waiting for the wastegate to shut again when I stepped off the clutch and back on the loud pedal. It came back on boost in the next gear pretty much instantly.   ECU / tune / BOV choice I think really comes down to a lot more factors than just what you've stated. And personally, especially for daily driving, recirc setup for the BOV, or no BOV. I dislike the really loud BOV when everyone is taking off from the lights etc.
