I am posting for a friend so u if you are interested just call him on 0405226046 or email him at [email protected]
- White buddy club P1's (17 x8 at the front. 17 x 9 at the back with G3 rubber) - offer a reasonable price. Fits on S15, r33.. dont know what other cars...
- Greddy pod filter kit - $100
- emanage (incl igniton, injector harness and with SD memory card) Used approx 2 months - *sold*
- e-01 - used approx 2 months. $800
- Pioneer MD head unit - MEH-P7350 - 50WX4 - $400
- S15 Splitfire ignition coils swap with standard coils - adds 7 rwkw proven on dyno - offer a price.
- Greddy boost gauge with Greddy a pillar mount - *sold*
- Stock S15 springs - hahaha offer me a price.
- S15 floor mats - *sold*
post here, email ([email protected]) or ring him (0405226046)...
I will try to get some pics of the rims, headunit and boost gauge...etc...later
Thanks guys!
https://www.sau.com.au/forums/topic/26070-parts-for-sale-suit-s15-r33etc/
    • If you have a Nissan from Japan and model year is from 2016 to 2024, just say you have an Infiniti Q50 4 doors... Why are telling you have an import?
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
