Hey
I bought a near new set of BRIDGESTONE POTENZA RE55 S tyres which I will be running on my car occasionally on the street but more directed at track work
Just wondering what the life expectancy of these tyres are, I will be mainly using them for track but occasionally clocking up maybe 100km a week on the street
Do they wear out reasonably quick on the street?
Would it be preferable not to run them on the street and only on track?
What sort of km would I get out of a near new set till they are useless?
Main reason I ask is that I don't want to run them on the street and burn them down real quick or wreck them, if that's the case then I would rather change to a set of normal street tyres and only run the RE55's when I'm doing track work
Thanks
https://www.sau.com.au/forums/topic/260703-potenza-re55-life-expectancy/
I would not use them on the street, s the S is a soft compound tyre and will wear very fast.
It would also be a very harsh ride. Have used the SR2 compound ones on the street and it was not pleasant...
Best to have a second set of wheels with them on it and change for the track.
Also you would be very unhappy if you coped a nail in one driving on the street....
i know they are a completly different grade of tyre but a mate of mine has falken azenis rt215s on his wrx.. has had them on for over a year now and they are still in excellent condition.. it isnt a daily driver... so it doesnt rack up many kms... but when it does come out it gets a good thrash.. if he gets 2 years out them, that makes it $500 a year for the best upgrade yet.. money well spent.
I'm using SR2 compund and it lasts a while.....only cos its mainly parked at home! I knew i wouldnt get many kms out of it but i didnt realise they wouldnt be that great on the street, especially in the wet. They are ok i suppose for normal street driving, but for the money you are better off getting really good street tires. But i still like them :cool:
Thanks guys, that's pretty much what I needed to know
Although the car isn't driven Monday - Friday, usually only on weekends for short a short period of time, I would rather get the most out of these tyres on the track as I don't drive the car too hard on the street anyways
It's hard to get power down on the street with normal street tyres but might grab a decent brand and a new set of tyres to run around on if need be. I get strip & fits as well as balancing done for free so doesn't bother me if I need to get the street tyres taken off and RE55's put on for a track day every now and then but would be a shame to wreck the RE55's on the street!!
Thanks again
What tyre pressures you run is heavilly dependent on how many laps you are running, how hot it is, how heavy your car is, what compound the tyre is what the suspension set up is, whether it is the front or the rear of the car & whether it is the left or right hand side.
For sprints, hillclimbs etc the objective should be to get the things as near as you can to working temperature when you need them to be working. Loosely the lower the pressure the faster they will build temperature in the tread face. The problem being, however, that under pressured tyres offer less grip which hurts lap speed. So, as ever, it is a compromise.
Nitrogen? Well when you do a track day you let air out. So you will need a refill everytime you go to a track day. To be perfectly honest much of what is said about nitrogen in tyres is a load of bollocks. Air is 80% nitrogen anyway. Just try & use dry air.
I work at Bridgestone and i will tell you that they will wear very quick on the street. Some of our customers up here in Darwin only get 3-4 track meets from a set and that is only around 20 laps per meet. On the street they will be worst an not that great grip wise anyways due to the different and uneven surfaces. Only use them on the track and pressure wise will depend on how many laps your doing at a time and the weight of your car. The more you do the hotter the air gets etc. and then the pressure goes from 38 to 40+ very fast Lots of options but the cost is to high for these to use on the street. Buy some re001 for the street mate there wicked. If you can get your hands on cheap g3's there prob better but alot of the time there more expensive. \
Good luck
They're crap for the street. My car almost changes lanes when there is an uneven surface like at traffic lights (wheel wells). Noisy and they wear out quick. Just have another set of rims and tyres for the track. Heaps better... If you do run them on the street make sure they're not too low on pressure.
i love my re01's so much so i bought 2 complete sets at a bargain price! now I am told you cannot get them here any more and they reckon try the re001, they are absolutely nothing alike
I had Re01's on my car when it came from Japan and i managed to keep them through compliance, they were awesome!
Then i got defected and was made to change them, bastard's :3some:
I would buy the used re55 or similar from gordon levin, 40% or less usually on them
run them on my car for the whole year on the street, driving quiet often i would go thru a used set in about 3-4 months.
@ 50 bucks a pop or whatever they were thats pretty good for the level of grip in all conditions!
  • 1 month later...
I want to buy a full set of RE55's for street use... I wonder how they are in the wet? ABU, can u PM me were you bought the Tiress form and how much the prices are?
What different models of RE55's are there...?
trackside in kilsyth do em
  • 4 weeks later...
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
