  • Replies 48
try? give me your address and name. f**king poofWatergardens carwash.
now your just being a poof. give me your address. i'll knock on your door.as if i will give a loser my address. Name the place and the deal is done.
Tomorrow, after work 6pm. come to bell street maccas. ill be in a blue VN Commodore. bring some friends if you don't wana get f**ked too hard.Oh you fight like a panzy. "I'm the toughest, as long as i have 20 mates to one bloke"
hahahaha........You can have you gay orgy.
As i thought a mouse!
Oh you ignore me now? I'll be there anyway. so come dwn you poof. the only person thats gna kick your head is me. bring some friends to hold your hand
while your on the floor. your just a poof e-warrior
btw my numbers 0411789574. txt if you gotta go to the toilet. i don't wana here a poofs voice.
https://www.sau.com.au/forums/topic/260704-im-a-pewf/#findComment-4472343
Guest
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
