i've got a 32 gts-t with quite a few km's on it and a big turbo back exhaust and i'm looking for a few extra Nm & kw...
I'm thinking a turbo rebuild and 10psi
a pod with cold air pipe
tuning to sort it out
any ideas of any probs i may encounter with the std computer
any other mods that may be low cost (i've notice 'cooler kits are a bit pricey)
any recommended tuners in the sydney area
is a bleed valve the easy option to increase the boost
https://www.sau.com.au/forums/topic/26074-daily-r32-performance/
1) a high flow panel filter in the stock airbox with a pipe running from the bumper feeding cold air
2) bleed valve to 11-12psi
3) SAFC tuned on a dyno to get the best a/f ratios
assuming your engine and turbo are in OK condition this shoud yield some more power to play with... and should cost less than $500 all up...
Waz.
sounds pretty good. ta for the tip...
what exactly is a SAFC? a brand of piggyback computer? forgive my ignorance
going to rebuild the turbo to be safe as i don't believe it will put up with much more boost. what boost do the ceramic wheels normally put up with?
Hi cul202, I agree with mase, get a RB25DET turbo. swap the wastegate actuator from your RB20DET turbo. RB25DET is 0.4 bar whereas RB20SET is 0.6 bar. The RB25DET turbo flows more air at the same boost level, so gives around 20 rwkw more power. It bolts straightup, so cost is minimised.
Also makes a better base for a ball bearing hi flow later on if you decide you need more.
Hope that helps
That's spot on what i did sydneykid, thanks for the tip off on the wastegate in the other thread. Lots of fun. If you want a car for straight performance then the vg30 would be good but it's a tad lagier. Rb25 turbs is good if u like a bit of drifting and a more smoother power curve.
another option is to get your standard computer re-chipped for like $200.
for about $1000 you could get about 170rwkw.
Panel filter for standard air box. - $100
rb25 turbo - $500
bleed valve - $60
rechip computer - $200
gtr fuel pump - $200
that should be about $1000 and give you a reliable 170rwkw from your RB20.
After that, the next thing should be an intercooler. It's almost summer and the stocky one is a little small for that sort of power.
A GTR intercooler is now worth about $600. piping say another $400..
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
