Hey, can anyone recommend any good places to go to as far as front cuts, engines conversions etc go in Perth?
I'm looking to buy a cheap N/A (auto, yuck!!) Cefiro but I need to make sure that I can get it converted to an RB20DET / RB25DET (!!) / SR20DET as required.
Pricing for each of the front cuts obviously differs (from $1500 - $4000) but I just need to find out labour costs for the conversion and where I can go for expertise if I do some of it myself.
Thanks!!
https://www.sau.com.au/forums/topic/26076-engine-conversions/
If paul is gonna give u the details i think he is then thats prolly ure best bet. Radium st?
Chris Mills performance did well on my rebuild and they were pretty well priced. Although they outsource their tuning and dyno stuff to sst. So might be worth checking both places. Or even use CMP (chris mills performance) for the major stuff and sst to fine tune it.
Thanks a lot to everyone who posted and PM'd me. Don't actually have a car yet (sold the Civic VTi-R to be able get the wife a Supra) but I'm working on it!!
Just needed to make sure of availability / difficulty / pricing etc and it seems like there's plenty of people around who can help.
To Boostzor, GTS-t VSPEC and R32-GTS, I'll PM you a little bit later when things start moving along. Maybe one day I'll see you out on the streets and you can kick my ass in a drag!! :-)
See ya!!
Thanks!!
Why wouldn't you just buy one already done.
Price of a cheap auto 88 model is still around 250K yen in Japland and a manual , drift out , turbo one is around 450K yen.
Time you buy the front cut , get someone to do the convo and on the road then the 200 odd K yen will be cheap..
Cheers
Ken
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
