hrm?
35 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
query for the reader:
is there a market in SA for a custom ecu eprom tune? ie would you yourself consider doing a basic remap on your skyline?
something Im thinking of learning and doing...... learn on mine for a year until I am comfortable and then offer basic maps/install for others? it would take at least a year from starting out "feeling" etc, to being ok about offering a map to others.
I would arrange dyno time thru a reputable tuner, plug into your vehicle and gain info, write a base map, cut your chip out, solder in an adapter, plug in the base chip and check it out on the dyno, the tuner will be needed to operate and adjust for fuel (if adjustable, such as FPR) and ignition timing. Then write a remap... recheck on dyno. Use 2-3 chips per customer, around 2 hrs dyno time - should only be a $300 all up customer cost (map, ecu mod costs, soldering fee) plus tuners fee for dyno/service etc?
a good emprom usb writer and a bunch of chips and adapters plus a decent o2 wideband sensor kit would be over a grand start out costs.
problem is the chips & adapters..... costs plus the soldering in part ..... I could learn soldering, dunno we'll see
first off I'll buy a eprom ecu burner, wideband 02 & knock sensor kit and purchase some chips that suit my ecu adapter, and muck around with it on my car.
After time if it's all good I could get a bunch of chips/adapters and go nuts?
thoughts?
or is it all wank? no market for it therefore just a "thing" you do?
thinking outloud..... these knees are ruined, so got to find something I a). can do, b). enjoy doing & c). offer to others as a hobby & can be done safely under workshop supervision, so everyone is happy.
https://www.sau.com.au/forums/topic/260767-market-in-sa/
i say go ahead with it billie goat. at least you know if u ever change anything under the hood, you can do the tune! will save you alot in the long run, even if you just buy the parts to just do your own car.
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4473304
I'm not 100% sure on what youare proposing but if i have it right (your running a remaping service) then Jeff (Speedlab) already does this and he know's his shit backwards, i think that you will have problems with finding people to let you practice on their car as the result of getting it wrong will be VERY expensive, also you will need to burn more than 2 or 3 chips to get the tune to a reasonable standard. Jeff uses an emulator (and sometunes a nistune chipped ECU from the same model) to do his tunes which means he can do back to back runs changing the tune on the run and with my car it would have had 100's or runs over a number of sessions to get it to where it is now. For you to do the same thing you would be burning 100's of chips.
I think you have a simplistic view on what is an extremely technical profession.
Edited by D_Stirls
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4473950
yeah i say go for it tangles
as long as you can get it happening right i am sure that you will know what you are doing
after tunning a few cars....or your own car then you will get the whole idea of it etc
but i am with Dale on saying that Jeff already does this sort of tuning mate
so you will find it hard to get customers to start off with
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4474849
Fair comments, but I think Tangles is old enough and intelligent enough to know this.... just because there are already people doing this does not mean there is not room for more. You can learn and be good at anything you are passionate about.... if you have the time and the inclination I say go for it Tangles.
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4474952
It takes minimum 30-60 minutes to desolder/resolder an EPROM or board to an ECU. Soldering skills are essential as you dont want to kill a customers ECU!! The only Skylines which are single EPROM chip are R31 and R32. It will take another 30 minutes just to roll the car onto the dyno and set everything up... so theres an hour to factor into your time on top of tuning.
You didnt mention emulators here so I'm assuming you are going to burn/reburn? Thats going to chew a lot of expensive dyno time also so you are better off with an emulator so you can at least change maps on the fly. You also need maptracing to see which part of the maps you are going to use using NissanDataScan or our offerings
As others have mentioned Jeff does this all the time and has got it down to a tee. He knows his engines and tuning since hes been doing it for quite a while and got his base tunes sorted for many combinations making it cost effective. In addition to this he knows how the ECU code functions and has assisted me in finding more tables for things which fall in the special conditions part of the ECU (warm starting, idle control etc) for more special cases. Hes not the only one doing this stuff either since workshops in Adelaide using our stuff are already setup and Nistune is just an extension of ROM tuning. Just some food for thought anyways
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4489000
  • 5 months later...
Update:
Available to consult your ecu, diagnose errors, reset, chart / log info data, save rom tune, etc
Have full version Nissan Data Scan v1.53, and a decent dell laptop to diagnose your Nissan vehicle.
soon will have wideband analyser & a ecu rom emulator, with model specific (stagea or skyline) ecu chips.
I will be able to supply a base-map ecu rom chip that you solder in then check on dyno.
to do this tho I'll need to access a number of remaped ecu's such as my own.
not for another 12 months, but all in good time.
so here's to self learning :D
use my wcgn34 stagea as a mule to learn, and grab some base maps from r32, r33, & r34 (2.0L, 2.5L & 2.6L)
if you've got a remapped ecu id be interested in catching up one day and copying your rom hex data via my consult nissan datascan setup
chuck me a PM if you can help out.
cheers
Tangles
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4781368
Where I work we use eprom bases that you solder on the circuit board first then you can plug as many eproms in and out as you want without a problem just have to use an eprom tool. We also copy chips using an eprom copying machine. You just plug the original in one side and copy it to a new one next to it. I maybe able to help you with this sort of stuff if you need it. The circuit boards we sometimes get with the eprom soldered in allready we solder suck them out so it dosent ruin the tracks then install the bases. It is a quick job that way
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4783774
yeah all Id like to do at this stage is plug my laptop/consult into some skylines that run a Remapped ECU & download a 5min copy of the tune
no biggie tho, not ready to do anything with it at this stage (funds....)
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4787035
I have a stock 32 gtr ecu with a custom tune, you're more than welcome to download it
-D
https://www.sau.com.au/forums/topic/260767-market-in-sa/#findComment-4787048
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
