am putting together my rb30 using r32 skyline parts. From the manual i see you have to grind the lug down on the powersteering pump bracket so that it sits flush on the block have done this and bolted it all up. But when i had a test fit with the pully off the crank the pully on the crank does not line up with the powersttering pump pully?
Anyone got any ideas or pctures?
https://www.sau.com.au/forums/topic/260811-rb30r32-powersteering-pump-problem/
  • 1 month later...
How did you end up going with this? Your problems sounds really strange as the horizontal alignment is identical. If you didn't grind back the top lug all that would happen is the pump may require a different sized belt and the two bottom bolts wouldn't tighten up flush against the bracket. Its alignment with the balancer would not be changed.
Mine was no issues, I simply ground back the top lug on the r32 gtst power steer pump bracket and bolted it on to the rb30 block.
The Rb20/25/26's bolt the top bracket bolt hole to the head where as due to the additional 38mm odd rb30 block height you simply bolt the bracket to the block but this requires the protruding lug on the std rb20/25/26 bracket to be ground back flush.
I too noticed the rb30e power steer bracket looked like it would be suitable but didn't bother testing. :P
Edited by TheRogue
  • 3 weeks later...
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
