well, the stag is stalling. i'm presuming that its an AT issue primarily because when the car is warm (seems to run completely fine on cold start and idle in neutral is fine and steady), i start to get issues when slowing to a stop - engine revs drop RIGHT down, as though trans isn't dropping down gears? once these games have begun it stalls intermitently during accellerating when it need to shift up as well. engine revs drop right off to nothing, though it will intermittently pick up again as though the trans catches like when you jump start a manual. it's been doing this for a couple of weeks now because i've not had the cash to get it sorted. went to have it looked at the other day and was told it was the fuel filter being block up which while understandable why they thought that, doesn't ring right with me.
so i've got a couple of questions:
1. does my diagnosis seem reasonable? if you need more info before you can say yay or nay, let me know.
2. does anyone know of a reputable auto trans servicing centre they can recommend in perth?
or does anyone have a consult cable and software than can read the fault codes for me?
cheers,
Dave.
https://www.sau.com.au/forums/topic/260818-stalling-stag/
yeah mine did that when i put the breaks on also, would just about stall.
i had a transmission gasket leak. loss i pressure i put it down to.
now im up for a rebuild LOL ! take it to any trans workshop who can hook it up to there comp, or nissan dealer best bet. dont leave it too long. left mine for about 12,000km's and got the worst result hehe :P
all the best dude
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474035
do you still have your standard BOV in place? have you blocked it or removed/replaced it?
yep she's still a complete stocker apart from the almost mandatory stereo upgrade. why's that?
"yeah mine did that when i put the breaks on also, would just about stall.
now im up for a rebuild LOL ! take it to any trans workshop who can hook it up to there comp, or nissan dealer best bet. dont leave it too long. left mine for about 12,000km's and got the worst result hehe :)
all the best dude"
yowsers - i'll be a little pissed if i'm up for a rebuilt only 8months after buying it :/
any idea of ball parks prices i'd be looking at for an AT service?
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474122
hmm my M35's been doing that lately. i've been questioning the transmission ever since i bought it...
Had the trans serviced only 2-3 months ago though...so hopefully its not the trans for me...i think mine's more related to steering somehow...but anyway.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474158
If you don't know how long it's been since it has had a replacement fuel filter, I would at least just do it for the sake of it. They are inexpensive and as far as i am aware, look pretty straight forward to do as it is nice and accessible in the engine bay.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474230
had this done the other day, no difference - stalled about 200m up the road from the service place. initially i thought it was related to my p/steering as well, however had steering pump fixed at the same time, still stalling. have done some additional searching and people have been having the same prob tracked back to various sensors such as engine temp and air flow meter. will have a look in fast tonight when i get home to see about replacing them
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474246
not sure if it will fix your problem but reset the ecu by disconnecting the battery, pressing the brake pedal a couple of times and leaving the car for half hour or so. then come back and connect it up again and let the ecu start fresh :/
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474414
ball park figure for a service ... $150 . . .
i only owned mine for about 8months i think. previous owner had it for 11months (finacial problems, nice guy)
i just got the ticking time bomb, car's done 107,000kms now, got it at 84,000 if those numbers match up, get the service kit done, that ways its open for a reason, get them to do some ECU testing, in one hit
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474450
cheers mate, will try get it done next week sometime - going to be riding for a little bit i think :/
" not sure if it will fix your problem but reset the ecu by disconnecting the battery, pressing the brake pedal a couple of times and leaving the car for half hour or so. then come back and connect it up again and let the ecu start fresh :) "
cheers mike, will try both the ecu and AT comp in the drivers side kick panel as well when i get home tonight.
Dave.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474471
OFF TOPIC
oh yeah and something i found out also, (just a little easier for people to read)
click the QUOTE tab on the post you wish to quote,
if you wanna quote a few, the tab will go red, then you can click on the next quote and so forth....
then when done click ADD REPLY and thats were they'll all be :/ took me some time to work it also
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474512
If it were just under braking i would have thought your brake booster has a vacuum leak but if its playing up shifiting upwards through gears you could be in dramas. A service never hurts - its something that should be done routinely anyway so may as well do it and if it fixes your problem then sweet.
Definitely sounds like a leak tho. Did you try the ECU flash...?
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474564
cheers,
Dave.
Sounds reasonable buddy...loss of fuel would deffinatly do this, and seams its not an expensive thing to replace a fuel filter try it first. If it doesn't work at least you've got a clean fuel filter in.
But on the other hand does the M35 run a accelerator cable or is it electronicaly controlled?
My mates BA ute(ford) is having similar probs at the moment. The mechanic thought it was the throtle possision sensor/swithch. Just another idea.
Edited by mattye
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4475060
Hope i'm not confusing things by what I posted. I think the original post was about a series 1 stag. Mine is an M35 and I'm not 100% sure but I dont think it has a fuel filter. It does have drive-by-wire though. The s1 stag has a fuel filter but not electronic throttle.
mine's due for a service sometime so will just get it looked at then.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4477751
I solved my M35 stalling problem by having the TPS (throttle position switch) reset. I am not sure if this will help you but it did stop the stalling. It does now idle about 100rpm higher than I would like but it is better than stalling every I pulled up quickly. It now idles around 800 - 850 rpm in neutral and it is meant to be 750 rpm.
To reset the TPS it is just a sequence of turning the ignition on and off with minimum time for each part.
1) turn ignition on for at least 2 second.
2) turn ignition off for at least 10 seconds.
3) turn ignition on for at least 2 seconds.
4) turn ignotion off for at least 10 seconds.
this is meant to reset the TPS.
I think the stalling may be slightly to do with the TPS but I suspect it is also to do with either the O2 sensor or the spark plugs. This is not a definate answer but it is my gut feeling.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4477787
Cheers
Andy
Awesome!! Hopefully this works for me. I didn't realise there was such a way to do this...
Mine idles on 500rpm (no kidding) sometimes less but the needle wont show much below 500rpm - and about 600-700rpm with a/c on. I know it should be higher than this and it doesn't just affect idle, it feels a bit dead sometimes when just cruising along - like it just drops out until i touch the accelerator again.
The other thing it affects is that it rolls backwards if i'm on an upward incline and i lift my foot off the accelerator. normally auto's shouldn't do this but ours does and its a bit disconcerting :S
Hopefully this is a simple fix otherwise I've thought maybe I need to get the idle adjusted (can you do that?).
Its really only started stalling lately - and only with a/c off (a/c lifts the revs a bit you see) so I'm pretty certain its just something simple like the above. Will let you know what happens...
Other suspicions i have are air-flow meter or spark plugs (no idea what they used in compliance).
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478078
There is no way to adjust the idle speed. It is all done from the TPS and the computer.
Try and look for the G35 service manual on line. Lots of useful information that relates to our cars.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478313
Cheers
Andy
I've tried resetting the TPS like you said, and I've also cleaned the AFM and reset the ECU (disconnected battery), but its still doing the same thing. Drives fine out on the road but when idling it seems to drop really low then quickly steady itself at 500rpm, where it doesn't feel smooth since its idling too low. It does make the steering harder too when its revving this low.
Will check the manual but its looking like a faulty TPS or something like that. Any way to check ECU fault codes by myself? or do I need to take it to Nissan (or someone with a consult cable & software) to do that?
I knew a lot more about my old stagea (series 2) but with this one I'm having to start over...learning it all again.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478429
You mentioned that you were not sure what they did with plugs at compliance. The standard plugs for these cars are Platinum or something similar and are good for 80-100k km.
I have been reading about the Blatz, IBDII software and cable and from what I have read, although there is a lot more to read, it should help with the fault codes and allow you to reset them. At about $200 bucks it sounds like a good investment.
http://www.blazt.biz/index.php
I have also listed below the info from the manual. Some of this may help.
Accelerator Pedal Released Position Learning ABS0003L
DESCRIPTION
“Accelerator Pedal Released Position Learning” is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning ABS0003M
DESCRIPTION
“Throttle Valve Closed Position Learning” is an operation to learn the fully closed position of the throttle valve
by monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch “ON”.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478534
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
