hey there'
so my car is going to try getting rid of shuffle (RB26, garrett -5's) going back to standard BOV, dirtgarage said that the HKS balance pipe did a good job, but cant be bought anymore, and expensive around 1k?
my mechanic suggested making one up??????
any suggestions?
https://www.sau.com.au/forums/topic/260820-26-5s/
try the stock bovs first i do not get any shuffle at all :P
yeah crap, i have read so much stuff about this, but my tuner insist on not going back to stock because of the leak?
i dont really want to 'tell' him to put them back on?
but i should really aye
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4473989
they are ment to be good for like over 600kw are they not?
i only have 300kw atm on 15 close to 16psi but yeah no shuffle so far....
ill let you know how it goes once i rewire this fuel pump and add some more boost :P
what mods do you have?
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474015
ill let you know how it goes once i rewire this fuel pump and add some more boost :/
hey, custom made dumps, custom made inlet (prob half the problem there!) injectors, pump, G4 link, profect b, etc etc running 18lbs 310 RWKW, stock internals, cranking boost to 20lbs soon.........
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474157
Stock GTR bov's leak?
Yes
@ Idle they open and this helps avoid the comp surge.
same as the stock rubber piping etc etc.
Nissan made the RB26 setup perfectly in that respect. You have issues only when you go hard pipe kits, take off the stock BOV setup etc etc.
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474261
I have -5s, HKS hard pipe kit + Drag Cooler, standard exhaust and inlet manifolds, 20psi, NO BOV, NO SHUFFLE.
Many people have recently had this problem, its related to the turbo intakes, BOVs, and a few other things I cant remember.
Id be looking at your inlet. Its the only thing different.
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475369
heres my inlet, it would be a pitty to scrap it.
any ideas ?
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475848
i have stock intake with pods stock dumps stock bovs stock cooler and air flow meters
my guess would be its your bovs... are they adj?
maybe try differnt setting harder or softer?
yes they are adjustable, my mechanic said he would try a softer spring.......
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475857
What R31 Nismoid and femno said :banana:
I have the same setup and no shuffle either.
As nice as it looks, I'd scrap it and go the standard bov's too.
dam i couldnt bring myself to scrap it, i didnt ask my mechanic to build it like that, but thats what he did, i dont want to through more money away too, might just get that BOV done, then live with the noise, just would like to here those ol' -5's spool up, rather then 'thomas the tank engine' on crack
cheers robbie
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475903
i get the same issues with my setup to the cchh chh chhh
i have std rebuilt turbos w steel wheel on ss manifolds, full hard pipe kit and no bov and pfc with afm just shy of 300kw but i recon its the manifolds not being tuned lengths or the hard piping not being the same length from turbos to intercooler. what i was going to do is run a 2 into 1 intercooler and make the pipe lengths the same from the turbos to the intercooler?
what do you guys recon? and im not giving up the the hard piping kit lol
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475950
nice intake mate!
leave it and try the stock bovs first
hey thanks for that,
yeah going to try a softer spring first on the HKS BOV, then will prob leave it at that, may go back to stock if i ever have anymore spare coin :)
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4477639
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
