Hello All,
Well my mate was going to give me an Apexi Power FC but after checking the site it is clear that they are not too compatible for Stags. He just imported an Evo FQ320 the greedy bugger. . .
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
So my question to you learned Turbophiles is:
What other complete units are there for the M35 that I can get. .
Jules
Ben at North Shore Prestige said the a Haltec system has been tested on the M35. I think he mentioned a figure around the $2k mark.
Pretty sure it was done Unique Autosport in Brookvale.
Cheers
Andy
Cheers
Andy
Yeah I spoke to Herman at Envy Imports. . . they do a small basic one for around a grand, then the $2k one and the $3500 one. They didnt have any figures to show regarding improvements etc. . so I didnt get one but happy to review once some real stats are available.
Was told to expect at least 10% gains in power fuel economy etc etc. . .but I am a "Must see figures" man or someone swears by it motto. .
Yeah, I have spoken to Herman as well.
They were using the 350z standalone ECU as a piggyback initially.
Cheap one is the "Interceptor", medium is the e11 (I think) and the expensive is the 350z Platinum.
He stated that figures were roughly 10% increase in economy & 20% increase in power...
I have also been told that I can expect at least that with an eManage Ultimate.... Fair bit cheaper too!
Waiting on a response regarding the Vipec as it is stand alone also.
Will let you know.
thats the place.
I know Jetwreck has planned to do the Haltec, he is expecting around 240kw from memory.
But he is also highflowing the turbo as this is now a necessity. We should know some results on the turbo in the next few weeks.
The basis one sounds like what I would like to do. small performance gain fuel economy gain.
The next few weeks will yield some interesting results.
I'm all for high flowing the turbo in my M35 too, probably won't be looking at it for a few months though.
I was talking to Unique Auto Sports about it the other day, they said Engine Management would be a problem ;)
When someone finds a good, cost effective solution be sure to let me know :)
i think your best bet is the Vipec/Link computer. Have a read of Skidkid's successfull installation in his S2 auto (and dirt garage's OTT praise). The Vipec has the computing power to do it all and it is a current model still being improved and supported (unlike the PFC). The main thing is to find a competent installer (as skid kid seems to have found). A new computer will not on its own necessarily produce a lot of power but it will get the maximum from any mods. It will very likely produce some economy though because Nissan's standard settings are conservatively rich.
since an aftermarket ECU install is really only as good as the tune, i'd recommend sussing out local tuners first and seeing what ECU they prefer to install and tune. Unless you like limping/towing your car across Sydney to get something looked at one day if there is a problem/question you have.
Well, I have just been talking to Trent from Status Tuning down here in Melbourne's South East.
Since I have an eManage Ultimate I have been talking to him about which way to go.
Here was his last reply (quick sum up)
"To be honest i reckon you could get 95% of the result with the emanage ultimate (get the optional map sensor and harness) the Vipec/Link install will require far more work to get right or even to the same point as the emanage. The auto control is the trickiest part and the emanage seems to integrate pretty seemlessly. What size turbo are you looking at? and eventual target AWKW? as these two really determine the best ecu direction. say 250 as a max and i would go the emanage route, say 300 and up and the extra work with the LINK/VIPEC would pay off in the long run"
Hope that helps guys.
If you need to go the eManage Ultimate, there are usually a few floating around in the For Sale threads.
Edited by iamhe77
I was looking at getting the OBD II software to monitor the functions of the car to get a better understanding of what the car is doing.
looks to be pretty cool software with the ability to monitor all sorts of functions under the bonnet. I can see that it works on the V35 and using a bit of "leaping faith" I would think it should also work on the M35.
Understanding how and why this car performs ma help getting the right tune.
Could be wrong though.
Cheers
Andy
Where are you getting this software from & how much?
Does it plug into the Consult connection?
Yes, plugs into the Consult connection. Cost is max $215 for the full version with data loger.
See web page, http://www.blazt.biz/index.php
Also read thread with other comments, http://www.skylinesaustralia.com/forums/Ni...or-t253127.html
Cheers
Andy
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
