Hi people, once again I have a question. I got a second hand crank from a friend that replaced it for his build, it is an R34 crank 05U on the crank and the engine had a spun bearing. I got the crank checked and the machine shop said that they may have to remove .010-.020 on the rod journal and at the same time do all to measure up. They said that the mains are all fine, what I want to know is if I have the crank ground can I get rod bearings that are .020 oversize? I spoke to one person and they told me that they only come in .010" nothing more, do I have an option for bigger sizes in the rod bearings? Let me know ASAP so I can know if I need a next crank, reason I took the crank in the first place is that it already had the long snout.
Jason.
https://www.sau.com.au/forums/topic/260887-crankshaft-grinding/
The journals are undersize when the crank is ground, but anyway I'm fairly sure the first undersize available is .025, so you should be fine. Someone else will be able to confirm or otherwise.
I've ground a few cranks before. Did you have crank checked for straight aswell because I reckon you would be real lucky if crank wasn't bent. Means it will require a grind all over if not to bent. Doesn't your machine shop supply bits? Have you googled for 'ACL bearings' site?
Yes I was looking on the ACL site but I wanna make sure that I can get the bearings before I go ahead and begin the repair process. Seeing that people are suggesting it is possible to fix it then I will go ahead and get it done and order a set of bearings based on the size after machine work. This is going on a spare RB26DETT that I am going to be building up. It is getting some CPs and rods. Will let you know how it goes and I will contact ACL tomorrow to get a definite answer.
Best to get the bearings your machinist suggests, then give them to him BEFORE he grinds your crank, that way he can mic up that specific set of bearings and grind to suit.
Edit: 1pm Friday here.. and I knock off in an hour :D:banana:
Edited by bubba
http://www.aclperformance.com.au/NissanRB26DETTBearings.htm Is the link you want, the bearing sizes are metric.
First line of sizes is STD then 2 oversize bearings to suite a ground crank.
But like the others said get the bearings they recommeneds then take them to them and get them to machine the crank to suite the bearings.
acl do 10 and 20 thou in race series, ndc do them up to 30 thou. just look at sr20 ones, there the same. just have to buy 2 sets..
you can also have it offset ground to remove less but give a 10 or 20 thou stroke increase wich is f**k all.
Thanks a lot for the responses. Should I worry about removing the nitride coating on the crank. I have read that removing the coating causes the bearing to spin very easy, can someone confirm that has ground their crnak and has been running it for years?
Just got confirmation that the crank is bent and that it can straighten it and the mains will have to be ground .010" and the rod journals .020". Your thoughts on this and has anyone ever heard of straightening the crank, the shop said they have a unit specifically used for this process. This is news to me.
I have straigtened a few with success and broken a couple aswell. You may be lucky. Make sure they cracktest it for you before they grind it!! Never used to worry about re-nitriding and don't think it caused a problem. The decision to go ahead rests with you though!!
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
