90's mustangs (which are nuggets :banana: ) can be had for cheap as over there!!
When I was there a couple weeks back, on La Brea Ave - from bascially a few km's out of LAX to Hollywood, I lost count how many used car dealerships there are!!
and thats just that road....used car market is MASSSSIVE there!
im sure you'll have no drama's getting a good car :D
Due to work, I may be getting shipped off to LA for a couple of years. While I'm out here for this trip I figured I would go and do a little browsing over the car market to see what I may end up buying if I end up out here long term. (Don't worry Steve. GTR ain't going up for sale).
Pheeew!
Would be a shame to see it go :blink:
Id go a Caddy :D
you gotta get something you can't get anywhere else.
the bonus is you get to bring it back to australia for $3k and no taxes and maybe make a profit.
You're in LA, always sunny, always parking, valet outside every restaurant, so get this for $15k:
http://www.dreamcarclassicsonline.com/cgi/...p;allphotos=L01
or look through these:
http://motors.shop.ebay.com/items/Cars-Tru...506Q2ec0Q2em283
Edited by moneypit
Surely you would go buy a Corvette, LS6 or lower perhaps..
That or a saleen or other musty.
Buy a house too because the market is piss week some people are selling up for $1000!
Everyone is broke so make sure you take them for all they are worth haha
over there, a hearse looks different. You haven't seen six feet under?
well over here.........it looks like a HEARSE!
no i havent seen 6 feet under
yeah i agree with you on that one.
the most sensible thing is to just forget about WASTING money on a car...
buy one to get you from A - B...
save up to buy a property... yeah ive read an article on how cheap properties are in USA at the moment.
and plus you'd probably never would be able to own a house in australia, like many young generations here.
oh well
the choice is yours
well the way i look at it.....ur wrong
the Miata IS, the MX5 with a different name
and in japan apparently its called "Roadster"..its only called mx5 in aust
just like the Toyota Yaris.........its still called "Echo" in some countries...
and "Vitz" in various others......
and in north america its called "Belta" and asian countries "Vios"
Agreed, they're all facts, apart from the mx5 only in Aust bit. I also apologise for the confusion my sarcasm has caused.
They look good in pics......but after driving one i can definatly say you'll regret buying it after having the r32
Got recent pics of R32?
I wish I had some. I had the car all washed before I left AU and forgot. When I get back I may get a professional spread done (need a poster for my wall :D )
Mustangs are everywhere in cali. After a month you will be sick of seeing them. They're like seeing a ford falcon in sydney.
I went and visited the Turbonetics factory in Simi Valley and one of the dudes wanted to trade me his mustang for an R32.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
