Hi I'm looking at a new electronic boost controller I'm currently looking at a new eboost 2, 60psi model I'm just wondering what otherr options are out there and around what prices they are.
By the way it's going on a rb30 with t04z and tial 44mm external gate. all i really want is good stable boost control with in cab adjustment and pressure gauge i think the eboost2 is a little pricey.
what are your thoughts on whats best
Edited by rodger1
https://www.sau.com.au/forums/topic/260893-which-ebc/
You wouldnt need the 60psi model would you. The 40 should be more then enough yeah?
Other wise blitz, hks or greddy ebc's are all very good.
I have eboost 2 and it is great but alot of workshops may not know how to set them up and cost alot more on tuning as they read through the instructions as they go. They are quite complex if your not used to them.
https://www.sau.com.au/forums/topic/260893-which-ebc/#findComment-4475243
i probably wont need the 60 psi model but i expect to be running 30psi as i have relatively low compression I think i might go with the greddy it seems the best for the price. the eboost seems to do too much and i don't need all of that stuff. Thanks to all of you for your help.
https://www.sau.com.au/forums/topic/260893-which-ebc/#findComment-4475300
I believe GIZZMO MS-IBC is the best bang for buck. Awesome boost controller, takes only a few minutes to install.. it's so simple and works great!
MODYOURCAR had a special on them for about $300 brand new, I'm running one in my silvia and it holds 1.3 bar all day very nicely
You can also preset 6 different boost settings and reads in PSI or bar. It's adjustable up to 50lb (3.5bar) so plenty for what your wanting to do
http://www.gizzmoelectronics.com/Product_MSIBC.html
http://www.modyourcar.com.au/gizzmo-msibc-...ontroller-p5327
https://www.sau.com.au/forums/topic/260893-which-ebc/#findComment-4475315
